ringing while idling
14 replies to this topic
  • brandonmotocrosslife
Posted November 07, 2013 - 10:40 AM
hey so after my bike had been sitting around for about 2 weeks and i started it up fine but when i was reving the bike in neutral i heard some ringing coming from the clutch box like maybe some plates had been worn or something. so i opened the case to inspect the plates and everything looked fine. i also checked the kick starter idle gear to see if anything was lose there and nothing was loose. so i made sure everything was in correctly including the torsion spring which was a pain in the butt to keep in it's hole and put the bike back together. i did an entirely new oil change including the filter started it up and it was still making the ringing noise....
any ideas to what it could be??? thanks
  • woods-rider
Posted November 07, 2013 - 10:42 AM
Model and year would be helpful.
And maybe a video clip so we can hear the sound.
Edited by woods-rider, November 07, 2013 - 10:43 AM.
Posted November 07, 2013 - 10:43 AM
wr400f 1998
Posted November 07, 2013 - 10:45 AM
cant give you a video but it sounds like change in your pocket
  • redhurricane
Posted November 07, 2013 - 11:46 AM
without hearing it in person, initial feeling is crank bearings. really no way to tell without some investigation. Go buy a cheap harbor freight stethoscope and start listening to areas around the case, cylinder, head, etc.
  • 080
Posted November 07, 2013 - 12:08 PM
your 100% sure its internals motor not external?
  • Krannie McKranface
Posted November 07, 2013 - 01:50 PM
Probably something loose on the exahust
  • Billyboypaints
Posted November 07, 2013 - 02:01 PM
Make sure it isent something stupid like the top of the rear shock .locknut not tight .or shock bushings beat .hope its something like that .bill
Posted November 07, 2013 - 05:25 PM
yup
no everything is nice and tight i had to take the exaust off anyways to get to the clutch plates
  • JDLowrance
Posted November 07, 2013 - 06:24 PM
There is an intermediate gear between the clutch hub/clutch shaft and the crank shaft. The nut can work it's way loose and sound like jangleing change (Aussie change that is). You have to pull the R-H engine side cover to access it.
Had this happen on two of my Yamaha 4 strokes. The nut will not come completey loose as there is a lock washer (similar to the CS sprocket nut lock washer) that prevents this but it's still anoying none the less.
Edited by JDLowrance, November 07, 2013 - 06:25 PM.
  • woods-rider
Posted November 07, 2013 - 06:29 PM
What kind of exhaust do you have? This sounds very odd to me.
Posted November 07, 2013 - 08:37 PM
yup
Huh??
Posted November 08, 2013 - 05:57 AM
i had to take off the header in order to take off the case
i meant header sorry
  • jackiefresh69
Posted November 27, 2013 - 01:16 AM
bashplate?
  • dukesilver
Posted November 28, 2013 - 04:09 PM
Ya, agree with bashplate.  Let it idle and simply put your hand on the plate.  See if the tone changes.
