2010 YZ450F
11 replies to this topic
  • coppolaj
Posted November 05, 2013 - 03:31 PM
I just Bought a 2010 YZ450F and after 3 rides it's back firing and has no power, Idles fine.
  • KJ790
Posted November 05, 2013 - 03:53 PM
Check your cam timing. It is possible your cam chain jumped a tooth on the timing.
  • Greg Pennsiltucky Lykens
Posted November 06, 2013 - 02:31 PM
sounds like a leak in the exhaust system or a worn out silencer. Something along the lines of repacking and a new cylinder to exhaust gasket should fix it...
Posted November 06, 2013 - 03:05 PM
If it starts and idles OK, but won't go beyond that without falling apart, then it sounds like a plugged injector, clogged fuel filter, or a failing fuel pump.
  • rickallen124
Posted November 07, 2013 - 03:54 PM
Try running some injector cleaner through it, it may clean it up.
  • coppolaj
Posted November 07, 2013 - 05:07 PM
I think your right about a fuel problem. I don't see where a filter might be.
  • coppolaj
Posted November 07, 2013 - 06:12 PM
I put some in but hasn't made any changes so far.
  • rickallen124
I believe that you may have to disassemble the fuel pump to check/replace the filter.
  • coppolaj
Posted November 07, 2013 - 06:13 PM
The dealer said the same thing. We might the filter be on this beast.
  • coppolaj
Posted November 07, 2013 - 06:21 PM
Sounds like I'm pulling the pump tomorrow.
Posted November 07, 2013 - 08:13 PM
The filter, last I heard, is not "replaceable".
Read:
http://www.thumperta.../#entry10702600
  • coppolaj
Posted November 07, 2013 - 08:22 PM
Read:
That sucks.
  • 10 replies
  • Hot  47 replies
  • Hot  113 replies
