Oil Screen Wrench
7 replies to this topic
  • Guest_Guest_*
Posted April 28, 2001 - 01:59 PM
Does anyone know if someone makes a line wrench to fit the Oil Screen on our WR426's? I started to use a regular wrench and it started to round off the nut. Maybe Snap-on or Craftsman? Also, what exact size is this fitting? With the paint and it being rounded a little it's going to be hard to tell.
Thanx, :)
Dennis
  • YZ400Court
Posted April 28, 2001 - 05:10 PM
Sears.com, search for "flare nut wrench metric".
www.sears.com
pretend it's flat and give it the gas.
[This message has been edited by YZ400Court (edited 04-28-2001).]
  • sclaus
Posted April 28, 2001 - 07:58 PM
I checked-out the "flare nut wrench metric" out on sears.com, and it looks like it only goes up to 21mm. Isn't the screen nut 24mm?
I saw a post that said to get a 24mm deep socket and a breaker bar for the first removal. I need to do mine this weekend and need a solid-solution as well.
  • MN_Kevin
Posted April 29, 2001 - 04:26 AM
I used a socket...it worked fine.
'99 WZ with all YZ mods, de-octopused, FMF PowerBomb header, Stroker SX-1 silencer, SS front brake line, forked over by Pro-Action, OEM YZ tank, IMS YZ seat, carb mods by Jim Dean and Sir "Taffy" from Jolly Old England, AMA, NESC.
  • Guest_Guest_*
Posted April 29, 2001 - 01:48 PM
I thought it was a 18mm. I hope so because thats the size I ordered from McMaster Carr.
Dennis :)
  • Guest_Guest_*
Posted April 29, 2001 - 03:26 PM
Ya , I got my mic. on it and it is a 24mm. Oh crap!!!!! :)
Thanks for the help anyway!
Dennis P.S. Does anyone need a 18mm Flare nut wrench!!!!! :D
  • Russ_P
Posted April 30, 2001 - 03:30 AM
Dens,
I use a 15/16" deep 6pt socket. 24mm = .945" and a 15/16 = .9375. The 15/16 actually fits better and I found that my local auto stores had it readilly in stock, not so with the 24mm.
  • Guest_Guest_*
Posted April 30, 2001 - 01:01 PM
Thanks Russ, I found that out also!
Dennis
