Bike level
3 replies to this topic
  • RMK800
Posted November 03, 2013 - 02:47 PM
I've been curious about this. How do you guys make sure your bike is level? If you change tires sizes, suspension etc. what do you measure to make sure it's level. Do you put it on a stand and measure each tire to ground? Do you put a level on the bottom of frame? I really have no idea.
Thanks.
  • Krannie McKranface
Posted November 03, 2013 - 04:11 PM
Level?
You measure suspension sag, and adjust for approx 30% rider sag in front and 25/100mm in the rear.
You raise and lower front fork clamps to change steering geometry.
You change heights of seats, bars, and pegs.
... and that's it.
But you do not measure 'level'.
  • RMK800
Posted November 03, 2013 - 05:35 PM
So even before a new bike is even sat on, the manufacturer's don't have a set spec for being level? Forks to high or rear to low etc. They have to come somewhat level and what are their guidelines? I guess I'm trying to find that starting point, then adjust sag etc from there. This isn't for my WR, but I like this forum. This bike has totally different forks and rear shock over stock.
Posted November 03, 2013 - 05:52 PM
There is no such thing as factory level.
Where would you put the level?
Who cares, if the springs are all wrong, if it's level?
I think perhaps you do not understand the concept of static and race sag.
You are not adjusting anything be spring weight and compression.
This will get you into the 'golden'  handling that all manufacuers build their bikes to meet.
Without knowing your weight, they cannot meet this goal.
You have to perform the measurements and spring changes to make it happen.
The static sag is nearly the same for all bikes:
front = 15% of travel
rear 25-30mm
Race sag too:
front = 30% of travel
rear = 100-105mm
Unless you have the wrong suspension components, there is nothing else to know.
Perhaps you should divulge just what you have
If you have suspension components that were made for your bike......
