15/45 or 14/48 gearing 07 wr450?
6 replies to this topic
  • gadyv
Posted November 03, 2013 - 06:54 AM
Currently running 13/50 but I want more speed since I ride the bike onroad to the offroad sections.
I do mainly fire roads and open stuff and occasionally technical sections.
Whats your opinion?
Thanks Gady
  • Chas_M
Posted November 03, 2013 - 07:16 AM
15/45 would be OK if all you wanted to do was to cruise on the road but would be WAY to high geared for any dirt riding other than fire roads.  14/48 would be a much better all-purpose combo.
  • Krannie McKranface
Posted November 03, 2013 - 09:47 AM
How high of a speed are you willing to have in first gear, before slipping the clutch?
13/51 = 7mph
14/51 = 11mph
15/45 = 18mph
(approximate)
http://www.sprocketcalculator.com/
Unless you weigh under 170lbs, the stock WR motor will not pull 15/45 on anything but flat ground..........
Edited by Krannie, November 03, 2013 - 09:49 AM.
  • gadyv
Posted November 03, 2013 - 02:27 PM
Thanks for the replies, I guess 14/48 would be the way to go.
Does any of you know what sort of gear ratio they run on a rally bike in the Dakar or Baja?
Posted November 03, 2013 - 04:13 PM
Totally depends on the bike.
All the factory bikes have completely different transmissions from stock, so the gear ratios do not compare to stock.
The DAKAR Yamaha had 15/45, but who knows what was inside...(dirt rider)
  • gadyv
Posted November 03, 2013 - 07:28 PM
Thanks.
So now all I need to do is get my hands on a Dakar bike...
  • n16ht5
Posted November 03, 2013 - 08:34 PM
go big on the CS before you drop the rear at all, saves wear. You can fit up to 16t front, which I rode tech singletrack with.. 16/50
