2006 YZ450 clutch problem
3 replies to this topic
  • torkd14
Posted October 28, 2013 - 06:48 PM
Any help on this would be great.
I have a 2006 yz450 that I have been running a Rekluse exp 2.0 on since may of 2013. It recently quit working. I tried adjusting the cable first but it either worked like a normal manual clutch or you could put it in gear let out the lever, rev it and it would barely move forward. No happy medium like it's supposed to do. I purchased new friction and steel plates but it didn't fix a thing. Could my basket and pressure plate be screwed? I'm at a loss at this point. I am willing to replace them but don't want to if they don't need to be obviously.
Posted October 29, 2013 - 07:07 AM
What if you stack the clutch up as a normal manual clutch, the way it was originally?  If that works, the problem is apt to be the EXP unit itself, possibly jammed or some such so that it won't expand as it should.
  • torkd14
Posted October 29, 2013 - 08:11 PM
I'll try this out as soon as I can with the new plates. I tried taking the Rekluse out with the old plates and it did nothing to fix it. I had the clutch cable so loose the lever that protrudes from the case and attaches to the cable was pressed against the case. Still the bike only creeped forward as I reved it.
Should the plates be flush with the top of the basket? Currently the plates sit slightly below the top of the basket.
Thanks for trying to help Grey, everyone I talk to is stumped by this.
Posted October 30, 2013 - 06:18 AM
Remember that you have an '06, and it originally had 9 friction plates.  A common mistake, BTW, is to loose the 10mm ball bearing that goes between the inner and out push rods.  Creates all kinds of free play, but that won't cause the clutch not to engage.
The clutch plates will normally stack up to just about flush with the end of the basket fingers.  The boss (hub) has to show enough splines extending beyond the plate stack to engage the teeth on the inside of the pressure plate, but not so much that the pressure plate bottoms out on the boss before it applies pressure to the stack.
  • 0 replies
  • Hot  113 replies
  • Hot  30 replies
  • Hot  28 replies
