'02 426 Engine Noise
3 replies to this topic
  • Yammer-Hammer
Posted October 20, 2013 - 05:09 PM
On my last ride i noticed a strange noise comming from my engine, so every now and then i hear a grinding noise, its comming from the flywheel side of the engine and it sounds like metal rubbing, and its not consistent, ill hear it for like a split second then it goes away, and il hear it again maybe 5 or 10 minutes later. So its not a constant noise.  It more of a metal on metal rubbing sound.   Any help is appreciated.  and how much oil is behind the flywheel cover? Cause i wanna pull it without making a huge mess
  • jojo1224
Posted October 20, 2013 - 05:40 PM
Lay the bike on its right side and you wont loose any oil, I just had to pull my ignition cover because of a bad misfire and noise and found the lower bolt for the pickup missing. I found parts of it stuck to my flywheel and a bit on my magnetic drain plug. I ended up cleaning the flywheel of shavings and since I have lots of spares I swapped in a good used complete stator but not before I put locktite on all the little screws. I could see some damage on the stator and some small marks on the flywheel.
  • Thommo_400f
Posted October 21, 2013 - 01:22 AM
Check your chain for slap.
You would be surprised how often chain noise can be miss interpreted.
  • Yammer-Hammer
Posted October 21, 2013 - 08:51 AM
It can happen when not in motion, just sitting there idleing
  • Hot  113 replies
  • Hot  30 replies
