01 YZ426F exhaust
13 replies to this topic
  • lastsilverdollar
Posted October 08, 2013 - 06:58 PM
I have an 01 YZ426F and about to purchase an FMF Q4 off a 2010 YZ450F. Does anyone know if I'll have any issues with compatibility?
This is my first post so please feel free to slam me for being stupid.
  • Yammer-Hammer
Posted October 08, 2013 - 08:42 PM
Ughhh, i hope you know the 2010 exhaust is designed for the rearward slanted cylinder with the exhaust port on the back of the cylinder head, there is no way the '10 exhaust will bolt up to the 426
  • lastsilverdollar
Posted October 08, 2013 - 08:44 PM
That about covers it thanks!
  • lastsilverdollar
Posted October 08, 2013 - 08:59 PM
I don't know anything about newer bikes, but need to replace my exhaust. I can't figure out a good resource to figure out what pipes will fit my bike other than the make and year models covered in the Clymer for my bike. So I appreciate the input.
  • Yammer-Hammer
Posted October 08, 2013 - 09:21 PM
Only exhaust for the 01-02 426 will fit those two years, (as far as i know)  And is something wrong with the stock pipe and header??
  • lastsilverdollar
Posted October 09, 2013 - 04:35 AM
Yeah, the muffler itself is damaged from a boulder and makes the bike extremely loud. I was checking out eBay for one that already has a spark arrestor, but I guess I'll have to get really lucky.
  • dougtpg
Posted October 09, 2013 - 04:44 AM
Rocky Mountain sells a powercore 4 for your bike, and a header to if you need one. Hope this helps!
  • lastsilverdollar
Posted October 09, 2013 - 05:25 AM
Thanks, Doug, I'll check it out- the problem is that I'm a cheapskate.
  • Yammer-Hammer
Posted October 09, 2013 - 08:01 AM
You might have to rejet your bike after you install a new muffler, are you going to replace the header as well?
  • lastsilverdollar
Posted October 09, 2013 - 09:33 AM
I wasn't planning on replacing the header. If I just replaced the muffler with another OEM, but added a spark arrestor, would that affect it enough that it would need to be rejetted?
  • Yammer-Hammer
Posted October 09, 2013 - 06:02 PM
As long as its a stock yz426f pipe it will not need to be rejeted, and no, adding a spark arrestor will not require a jetting change, i added one and didnt have to touch a thing.
  • four-twenty-sixer
Posted October 09, 2013 - 06:03 PM
You can use the can from a 03-05 and it will bolt right on, I've got one from a 06 on mine but i had to make an adapter for the slip joint because the 06-09 pipe is bigger. You might have to go down a main jet size and turn your fuel screw in a little with the spark screen.
  • essex426
Posted October 09, 2013 - 11:46 PM
I also use an early 450 fmf Q and header on my 02 426.
Had to enlarge the hole on the subframe to bolt it up though.
  • lastsilverdollar
Posted October 10, 2013 - 08:12 AM
Thanks guys, Ebay is pretty limited so that helps a lot knowing there are a few other options out there.
  • Hot  36 replies
  • Hot  113 replies
  • 0 replies
