WR400 shutting down when driving
No replies to this topic
  • green1181
Posted October 03, 2013 - 08:53 PM
Hey everyone, in a bit of a bind and could really use some technical help :)
Bought a '98 WR400 recently and added the 426 carb because of the older
slide problem. The bike starts first kick with a few squirts of the accelerator
pump but not with choke on. Is this normal? It will run fine..until.....
after a few min the idle speed will decrease so when I come to a stop light it will die out if I don't adjust the idle screw. Also last time I had it out I was driving around 3-4000 rpm and the
bike just shut down..like an ignition problem since it wouldn't start until it cooled down
a bit..is there an easy way to check the spark when warm? (without removing the tank).
I tired loosening the fuel cap when driving and checked carb vent hoses to
see if there was a kink, no luck.
I really appreciate any input to help me get this beast back on the road :)
