09 yz450f hesitation? Stator?
2 replies to this topic
  • dch5110
Posted October 01, 2013 - 08:47 PM
Hi all, so as stated I have an 09 yz450f that has a hesitation(miss) at steady throttle. I tried researching and found many different things causing similar problems for others. so I began checking for exhaust leaks, broken or bare wires, even got into the carb and cleaned it all out checked the needle, changed needle position, switched out a few pilot jets, unplugged the tps, and checked the valves again. Still runs the same. So now im to the stator, I was going to check it for metal shavings on the pickups and such and didn't really find any. But I did find on the one coil a black spot and thought it looked like maybe something shorted out in there? Is there a way I can check this with a multimeter or something to verify that its bad before I drop money to buy a new one? any help with this would be much appreciated, this hesitation is getting quite frustrating       :confused:
Posted October 01, 2013 - 09:33 PM
The tests are in the manual.  They don't always catch 100% of the bad stators, though.  A broken wire can sometimes make good enough contact to ring out OK with a VOM.  Slap it on the bench a couple of times with the leads hooked up, see if it changes things.
  • dm09YZ250F
Posted October 03, 2013 - 10:08 PM
I have a 2009 YZ450F that had a hesitation, the hesitation is in the ignition,I tried jetting with no luck as well, do search there is alot of info out there
I purchased a MSD ignition and had Jesse at Williams MotoWerx put one of his custom maps in and the hesitation is gone and bike has more power, Love it !!
  • Hot  30 replies
  • Hot  38 replies
  • On January 15, 2017
  • 0 replies
