My 2012 WR450F runs hot.
24 replies to this topic
  • MidlifeCrisisGuy
Posted September 23, 2013 - 09:58 PM
#21
give it a try.
Thanks, I probably will.
  • vlxjim
Posted September 23, 2013 - 10:00 PM
#22
Yes, too advanced timing, insufficient octane or a lean mixture can all cause detonation and therefore overheating and damage.  Given that the base map of zero is a safe start point, can you explain or justify the benefits of  -1 degree in timing?
He is running a comp ECU and the timing is already bumped up. So as I said add some fuel and kick down the timing -1 at the low end is a place to start. The OP is running at slow speeds and his cooling system is being tested. What I have posted well help. If not something else is wrong. But seeing that he's running a stock Comp ECU this should help.
  • MidlifeCrisisGuy
Posted September 23, 2013 - 10:43 PM
#23
http://www.dirtbikew...ad.php?t=107474
  • MidlifeCrisisGuy
Posted October 06, 2013 - 07:55 PM
#24
I was out riding today.
I checked into exotic coolants like Engine Ice and Evans NVG+. I haven't pulled the trigger on them yet.
I checked the idle speed with the GYTR tuner and found it to be 2800 RPM. I adjusted it down to 1950. The bike is much easier to ride and stalls even less. My engine didn't overheat, but it was a bit cooler out too.
I loaded a bunch of maps into my GYTR tuner. Unfortunately I got an error (Cant communicate with the ECU) when I went to upload them. That will be the subject of a different post.
  • MidlifeCrisisGuy
Posted October 06, 2013 - 09:50 PM
#25
"Advanced ignition timing = more engine heat" at 5:10 in
