Baja Designs dual sport kit no spark
2 replies to this topic
  • BRADBRUCEWILLIS
Posted September 20, 2013 - 11:18 PM
Hello i've checked the sticky posts and done a search and was not able to find any info pertaining to my problem.  I have a 2011 wr 450 with a Baja designs dual sport kit.  After installing my DS kit everything worked great for about 6 months then all of the sudden my bike cranks but wont fire.  While troubleshooting i find the fuse on the baja designs harness is blown.  I replace it and the bike still wont start.  I pulled the plug and no spark.  I completely scowered the wiring system and have found no damage of any sort that may be causing a short.  I removed the BD DS rectifier and pluged in the stock unit and when I crank the bike no spark but as soon as i let off the starter switch i get one good hot spark from the plug.  I pluged in the BD rectifier back in and dont get anything at all.  What does this mean?  At this point i just feel like striping out all of the BD DS parts and returning my bike to stock!  Can I run the stock parts and rectifier with the modified stator?  Or do i need to replace the stator with a new untampered oem unit?  PLEASE HELP! :banghead:
  • KennyMc
Posted September 20, 2013 - 11:36 PM
I would recommend calling Diego at BD. Not open on weekend's though but they are usually very helpful.
  • William1
Posted September 21, 2013 - 10:39 AM
Check the kill switch. Also, the power switch on the right bar must be on, so confirm (with a meter) it is powering the switched leg on the BD harness.
