09 450f oil pressure
5 replies to this topic
  • rob the snail
Posted September 12, 2013 - 10:21 PM
have just done a big bore kit on a 09 450 and now it seems there is no oil pressure...
when i unscrew the bleeder on the side of the head no oil comes out and the oil galleries are not blocked...
when i crack the oil filter inspection drain plug, oil pisses out.
there does not seem to be oil getting up to the top end....all gaskets are correct and no gasket cement was used.....am at wits end.....pls can i get help
cheers rob
  • rob the snail
Posted September 12, 2013 - 10:25 PM
ps i have been meticulous and the bikes history has been 2 blowups before i bought it, it was blown when i got it
Posted September 13, 2013 - 06:42 AM
Have you ever looked at the oil pump?
  • rob the snail
Posted September 13, 2013 - 02:46 PM
yep. it seems to be okay. this has me stumped :jawdrop:
Posted September 13, 2013 - 03:05 PM
Both oil pumps?  The one in the case (the return pump) and the one in the small housing that covers that (the feed pump)?
Does it have the OEM oil pump cover on it with the safety tab sticking out on the inside at the center?  If it has a Ready Racing cover (identified by an "R" on a black cover, you can install the oil filter backward and block off oil feed to the engine past that point.
If the feed pump is OK, then you need to verify that the oil passages are clear by pushing oil through them from one end to the other.  Get an old gear lube bottle, or any other plastic bottle with one of the conical "squirt" tops on it, fill it with oil, and force it though the oil passages at the pump cover flange.  Review the oil diagrams in the manual.
Another possibility is that the return doesn't work, so when you fill the crankcase with oil, it never gets moved to the oil reservoir in the front of the engine so that it can reach the feed pump.
  • rob the snail
Posted September 14, 2013 - 05:32 PM
cheers i was not aware or it having 2 pumps
i will go suss it out
  • Hot  30 replies
  • 0 replies
  • 3 replies
  • Hot  38 replies
