FMF too loud
3 replies to this topic
  • beairmo
Posted September 08, 2013 - 07:13 AM
I bought my 2009 WR450 used and it was already fully uncorked and has FMF Factory 4.1 Titanium with power bomb header. I just repacked it and no leaks.
I am not happy with how loud the bike is and the popping on decel. I am considering a different muffler and possibly the FMF Q4 Ti.
Can anyone tell me how much the Q4 will quiet the bike down and what else to expect over the 4.1?
Thanks!
  • Krannie McKranface
Posted September 08, 2013 - 08:05 AM
It's about 3db quieter overall, and it's about 10db quieter at idle.
All FMF's have a loud 'peak' idle tone because the core is short and large in diameter.
You need to make sure you follow a special re-packing procedure:
Wire-brush clean the perforated core to remove carbon
Wrap the core with 00 grade steel wool 3/8" thick
Use FMF solid repacking wool (not the loose stuff) wrapped just tight enough to be larger than the can by about 3/8", held in place with masking tape
Compress it as you go to get it to fit into the can
  • five_pointe_o
Posted September 08, 2013 - 08:40 AM
Sounds like you're lean with the jetting if it pops on decel. Fmf should sell a quiet core that lowers the dB level a bit for your factory 4.1 exhaust, it would be cheaper than buying a new muffler/system
  • KennyMc
Posted September 08, 2013 - 09:03 PM
Like the previous poster mentioned. Might try this first.
http://www.fmfracing...Products/MX/599
