'07 YZ450F - Rear Suspension Shaft Rusted
4 replies to this topic
  • ticke2110
Posted September 04, 2013 - 08:44 AM
Can someone help me out please,  I'm having my suspension modified (I'v gained a little weight), the shop has told me that the Rear Suspension "Shaft" is extremly rusted and needs to be replaced.  When looking at the manual/online I can not see what is meant by "shaft" - can someone tell me please, what part could the shop mean by this term ?  They are telling me the rust issue is probably due to water not being able to seep out after riding/washing due to mud & stuff blocking the seep holes.
Your help is GREATLY appreciated.
  • MidlifeCrisisGuy
Posted September 04, 2013 - 09:09 AM
Probably the swing arm pivot bolt or one of the linkage bolts.
You might want to post this in the YZ forum.
Edited by MidlifeCrisisGuy, September 04, 2013 - 09:57 AM.
  • JDLowrance
Posted September 04, 2013 - 10:27 AM
Probably the shock shaft itself.
  • KennyMc
Posted September 04, 2013 - 04:51 PM
Well there is nothing in the microfiche parts that lists a shaft as a seperate part of the rear shock.  So it must be the shock shaft itself as pointed out above.
Posted September 05, 2013 - 08:47 AM
It's the shock shaft.  This is a common occurrence where people ride in wet environs all the time and/or wash the bike a lot.  Water accumulates under the bottoming bumper against the shaft and corrodes it.  To avoid it, slide the bumper up the shaft once in a while to clean and dry it out.
This is also a cross post (same question posted in multiple forums), and thus a breach of forum rules.
You won't find the shaft in the fiche because Yamaha does not support the shock assembly as a serviceable unit.  Parts are widely available from any KYB dealer such as SMART Performance or Suspension Direct.
