Looking for suggestion for upgrades to 2002 WR426
19 replies to this topic
  • tracker59
Posted December 24, 2003 - 01:49 PM
I'am a newbie to TT and am looking for suggestions for upgrades to 02 WR426. I just bought it and it's stock. I'am what you might call a senior citizen type and will be doing mostly trail riding in southeast. Grey wire?, throttle stop?,exhaust? I'am looking for good low end performance, not so much hair on fire top end.
  • HaremScarem
Posted December 24, 2003 - 02:26 PM
Remove the Air box lid, Purchase YZ Needle (OBELN, OBEKN) and stick it on the 3rd clip. No need to re-jet the main or pilot. Do the BK mod and knock the squirt down to 1 second. Replace the stock bars. "REMOVE" the butt plug in the muffler or if you have sound restrictions in your area, get the FMF Q.
  • Rattler88
Posted December 24, 2003 - 04:54 PM
First cut or grind the throttle screw so you will be able to find all the rev's that arn't there I think that you take
19mm off it witch is almost 3/4 of an inch.
Then get a after market pipe, I went with a FMF power core 4
and have been real happy with it however you will have to
rejet no big deal there's plenty of help here for that.
I also removed the air box lid before I rejeted,but most of my riding is farly dry.
The rear shock spring was a little lite for my 47yr old 215 pound ass so I replaced it with a Race Tech spring that is in my weight range, the stock one is set for a 170 pounder
(I wish, I think high school is the last time I was there :))the stock forks and shock work well once dialed in so I found no need to do more then the rear spring.
Other than that ride the hell out of it so you can get the
starting drill down.
Enjoy,Merry X-MAS Jerry :D
  • Sylvain
Posted December 25, 2003 - 08:37 AM
Hello, Ho! Ho! Ho!
You have about the same vital signs that I do
. What rate of spring did you get for the rear. I also feel that the rear shock spring is overstressed. Must be because of my age :)
Merry Christmas
  • Rattler88
Posted December 25, 2003 - 09:15 AM
You can go to http://www.race-tech.com/ and they have a spring rate calculator, I got a SRSP 6228 54,and like it,
I don't bottom out going off the 4 foot drop off's like
I use to and there's a lot of them at Octillo Wells.
Merry X=MAS Jerry :)
  • blue_beast_wins
Posted December 25, 2003 - 01:08 PM
I agree with Harem but would like to add the 450 cam mod and the James now mod just to make your life a bit easier on the trails.
  • tracker59
Posted December 26, 2003 - 06:39 AM
What's the b/k mod and squirt down to 1sec? Posted by HaremScarem
  • tctrailrider
Posted December 26, 2003 - 07:07 AM
Check this out, look in the Tech articles
http://motoman393.thumpertalk.com/
  • jwriott
Posted December 26, 2003 - 07:32 AM
I agree with all of the previous posts but would add the YZ seat and tank high up on the list.
  • HaremScarem
Posted December 26, 2003 - 09:49 AM
OR...just look at most of our signatures and you'll see the common upgrades. The tank and seat replacement is a must. Do a search in the WR section for any mod that you have questions about. There's a wealth of knowledge and experience at your fingertips.
  • BlueDragon
Posted December 26, 2003 - 10:34 AM
What does the clark YZ seat /tank do for the WR426? Also I noticed a 03 yz450 cam switch? What benefit does that do? I am looking for more mods to my bike as well.
Thank You :)
  • jwriott
Posted December 27, 2003 - 12:48 PM
The YZ Seat/Tank upgrade improves the handling dramatically. I estimate that I'm probably 4" farther forward after the change. The front end sticks way better. I have the Clarke 3.3 gallon YZ tank and I'm very happy wiht it.
The YZ450 cam gives you the auto decomp with YZ timing. You can advance the cam in the 02 and older bikes but you have to buy the specific cam for the auto decomp. In other words, if you want YZ timing buy the 03 YZ450 cam, if you want WR timing, buy the 03 WR cam. I wasn't sure if I wanted YZ timing or not so I advanced mine and I'd never change back. Now I just need to decide if I want the auto decomp or if I can spend the $150 on other mods.
I just put an FMF Q on this weekend and I'm pretty happy with the performance. It is louder than I expected however.
  • dale
Posted December 27, 2003 - 03:54 PM
Thank You :)
I wanted to try keeping the stock tank and went with a Gut Racing tall height Medium foam seat. I am happy with this. If you send your seat to Guts they install foam and cover for free.
The cam mod is a must do, but be ready for a lot more power. I got mine from TT member CW as it had the correct gear for the 426 chain. Go to the YZ450 forum and at the top is "YZ 450 cam mod-please read ". This will keep your busy for a while.
  • jwriott
Posted December 28, 2003 - 09:04 AM
Dale,
Did CW actually put a 426 cam sprocket on a YZ450 cam?
  • PowerFiend
Posted December 31, 2003 - 08:01 AM
Hello, Ho! Ho! Ho!
Merry Christmas
215 with or without gear? I'm 205 in street clothes and run a 5.4 eibach rear spring and stock fronts. If you are 10lbs. heavier, I would recommend a 5.6 rear to get proper rider sag and free sag. :D
  • dale
Posted January 01, 2004 - 07:40 AM
Dale,
He used a 03 250f gear as it is same as 426 was but has the auto decompressor.
  • Sylvain
Posted January 03, 2004 - 01:23 PM
Actually after the last weeks of festivities, Christmas/New Year and all the other gathering, I have to admit that it's more like 225/230 without gear !!! :)
I wish the meals were all diet but :D
  • GIXXER_JAMES
Posted January 06, 2004 - 05:29 PM
[QUOTE]
Do you have to get the tank or can you send your old seat to have it set up so you can be farther up on the tank. I have stock seat and that has been a complaint of mine
  • PowerFiend
Posted January 07, 2004 - 08:46 AM
[QUOTE]
[QUOTE]
[/QUOTE]
When going to YZF tank you have to use the seat too. The WRF seat base is to short and the wrong shape at the tank juncture.
  • jwriott
Posted January 07, 2004 - 11:01 AM
Powerfiend is right, you must buy a new seat and tank. Look for them used here and on Ebay.
