Won't start!
1 reply to this topic
  • Cowles52
Posted September 02, 2013 - 04:25 PM
I have a 2010 Yamaha YZ450F. I had some problems with it cutting out while I was riding. I took it into the shop n they told me it was the fuel pump going out. I replaced the fuel pump and the problem was solved. Then about a week later it started doing the same thing. I took it in and they told me the electronic connectors were wet n needed cleaning. So they did and again it ran fine for about a week. Now it just died out on me on the track n won't start back up. Every once in a while it will fire up for about 2 seconds then cut back of again. What in the world could this be?
  • 96Yamaha
Posted September 02, 2013 - 06:58 PM
It sounds like your bike has come down with a case of the ratchets. To cure this take a ratchet and drive it back words so the bike can be pleased hahaha. All jokes aside, for an engine to work it needs these basic things.
Air
Fuel
Compression
Electricity
Now I'm more familiar with a simple 2 stroke old bike so I'm not sure about all the fuel injection stuff and electronics. Just go through the basic check list of an engines necessities, or simply have it checked out again buy a specialist.
  • Hot  50 replies
  • 10 replies
  • Hot  36 replies
