2011 YZ450 breaking subframes
18 replies to this topic
  • nedted
Posted September 02, 2013 - 10:46 AM
I've broke two subframes on my 2011 yz450 within 20-30 hours of each other, and they both broke in the same place (in between the exhaust mount holes where the fender bolts on) and I was wondering if anyone else has had this problem and how to fix it. Below are some pictures of the subframe.
ImageUploadedByThumper Talk1378146536.185157.jpg mImageUploadedByThumper Talk1378146772.200881.jpg
  • phiderman
Posted September 02, 2013 - 11:15 AM
I cut the end off and made a new price out of steel and then riveted it into place. No problems since.
  • phiderman
Posted September 02, 2013 - 11:17 AM
Here is a picture
  • cattledog924
Posted September 02, 2013 - 11:52 AM
I have broken the subframe on my 2010 multiple times, twice in that same spot. I found a good welder, which is cheaper than a new frame. It has really pissed me off.
  • nedted
Posted September 02, 2013 - 01:05 PM
Thanks. I'm gonna try to fix it like this. I'll post some pics when I'm done.
  • nedted
Posted September 02, 2013 - 01:06 PM
The first time I broke my subframe I brought it to a welder and they welded it for $20 but it only lasted one ride before it broke again.
  • kxboi704
Posted September 02, 2013 - 01:09 PM
quit casing jumps bud
  • cattledog924
Posted September 02, 2013 - 01:37 PM
  • DC_Excitement
Posted September 02, 2013 - 03:44 PM
are they breaking with stock or aftermarket exhaust?
  • nedted
Posted September 02, 2013 - 04:50 PM
I have a yoshimura full system on my bike.
  • nedted
Posted September 03, 2013 - 07:09 PM
  • Norton218
Posted September 04, 2013 - 05:40 PM
my 12' broke in the same place to.all so with a yosh slip on system.I now one guy that has a Dr.D system on his 12' and he has had no problems
  • DC_Excitement
Posted September 05, 2013 - 04:13 PM
I asked the question because it may be an aftermarket exhaust issue more than a Yamaha problem. I have the stock exhaust and hammer on the bike with a lot of bottom outs and its just fine.
maybe there is too much weight on that one mount?
  • asnyder2
Posted September 05, 2013 - 04:51 PM
Hope that its not related to having yoshi exhaust...I just got one recently
  • Aflo16
Posted April 04, 2016 - 05:24 AM
I just did this with my '11.  broke the subframe in the exact same spot.  I have previously had rub marks on my exhaust (FMF F4.1) so I know I was impinging.  When I finally had failure, it was a first ride on a new rear tire.  I had switched from a Pirelli Scorpion 120 rear to a Maxxiss Maxxcross IT 120 rear.  Did any of you have rubbing?  What tire/exhaust combo did you run?  Thanks.
  • cpetz24
Posted April 04, 2016 - 06:49 AM
Checking mine tonight.  I've got the stock exhaust though.  Common theme from above is that everyone has had an aftermarket exhaust.  Yoshi mainly.  Coincidental?  Maybe, but seems fishy.
  • F0Xryder61
Posted April 04, 2016 - 08:02 AM
50+ hours on mine with a full fmf 4.1 (i think) on mine. No problems so far...
  • Aflo16
Posted April 05, 2016 - 06:12 AM
I bit the bullet and bought a new subframe (albeit aftermarket).  I just finished undrowning my brother in law's quad so my bike is next up for reparis.  Going to take the subframe off and pop the new one on.  Then I think I'm going to spin up a spacer on my lathe to hold the exhaust a bit further out.  I haven't looked at it in detail yet so I am not even sure if there is room to space the exhaust out further but if there is... I'm going to have a new subframe and a newly made part that might solve this problem once and for all.  And for anyone that has not yet blew their frame off the back of their bike with their rear tire... it might be worth taking the extra step in preventative maintenence to rig up a space.  If sucessful - I'll post a pic or two.
Thanks for the info guys...and I agree - seems to be related to aftermarket pipes.  Still not going back to stock tho.... :thumbsup:
  • mikedabike
Posted April 05, 2016 - 11:25 AM
I know yosh revised thr mounting on thier pipes sometime after the 10 came out.
  • 5 replies
  • Hot  79 replies
  • 0 reviews
