Wr450 idling fast when stationary but when engage clutch goes down
8 replies to this topic
  • Fantazein
Posted August 31, 2013 - 03:26 PM
Bike started to idle fast when at lights and when I get clutch engaged and ready to go the idle soeed seems to lower and be near OK any reasons why this happens as been ok and when engine turned off a slight backfire
  • ohiocoalminer
Posted August 31, 2013 - 04:25 PM
Too lean
  • Thommo_400f
Posted September 01, 2013 - 02:29 AM
Possible you have an air leak.
Carb boot
Hot start
Fuel screw o-ring
Fuel screw not set properly
But high idle is lean (usually)
  • Fantazein
Posted September 01, 2013 - 03:20 AM
What do I do to overcome this
  • GuyGraham
Posted September 01, 2013 - 11:25 AM
what you have been told
Carb boot - Check if loose
Hot start - check if loose, or not seating
Fuel screw o-ring - check condition
Fuel screw not set properly - adjust if required. What is your current setting
  • timmytimmytimmy
Posted September 01, 2013 - 06:24 PM
can someone help me out with my side case problem plz would much appreciate any advice
  • fixitandy
Posted September 01, 2013 - 09:21 PM
G'day, if your bike was running correctly prior to this, check air boot & manifold connections to carby, but most likely hot start not seating properly, remove, clean, & apply a small amount of anti seize in there, you should be able to hear it seat with a click. ROOSTA out.
  • GuyGraham
Posted September 02, 2013 - 09:52 AM
take it off, you don't really need it.
Its only keeping the oil in, which is just excess weight you have to drag round
  • Zimman
Posted September 02, 2013 - 10:20 AM
you hijacked  someone's completely unrelated  thread to get a response to yours  ?
i have 03 wr450f with hole ine case frome kicke start gear
I was looking to see if you were from another country  LOL
bad phone text?
Edited by Zimman, September 02, 2013 - 10:20 AM.
