YZ426 not starting after top end rebuild - any help?
8 replies to this topic
  • amooney301
Posted August 27, 2013 - 08:21 AM
cam alignment.jpg flywheel mark.jpg I've got a 2001 YZ426f in which I just performed a top-end rebuild. Timing appears to be correct, I have spark and I've got fuel to the carb.
Any ideas???
  • brandonvick83
Posted August 27, 2013 - 08:58 AM
Is there compression?
  • amooney301
Posted August 27, 2013 - 09:53 AM
Plenty of compression. Engine turns over similar to before rebuild.
Posted August 27, 2013 - 10:11 AM
Is the exhaust cam an aftermarket cam for a 426, or a YZ450 cam?
  • amooney301
Posted August 27, 2013 - 10:40 AM
I'm not totally sure. It came off of another 2001 YZ426. Is there a way I can tell the difference? How will this affect timing?
  • MrKTMrider
Posted August 27, 2013 - 10:48 AM
Cam lobs are different.. the YZ450 keep both valves closed longer ...thefore more compression and that way the timing is affected.
  • amooney301
Posted August 27, 2013 - 11:43 AM
This was the same exhaust cam that was in the bike several weeks ago when the bike was running fine right before I tore it down to rebuild.
Any specs that I should be aware of for each of the cams? Are there certain measurements in which I can identify which cam I have?
Posted August 27, 2013 - 05:18 PM
If you are sure of that fact, then it's likely that the cam was made for a 426.  OEM Yamaha 450 cams can be used, but the original timing marks don't work because of differences in the way the head is laid out; valve angles and such.  You should be OK.  Take a picture of the cam lobes from the other side of the head with the timing marks lined up.  Then we can be more certain.
  • amooney301
Posted August 27, 2013 - 07:19 PM
I believe I found the issue - Seized crank bearing!
I was able to get bike started, it ran for approximately a minute then stalled. I was positive that the timing was correct. Disassembled down to the piston and found crank bearing seizing at one point in the crank rotation.
Thanks for the help.
  • Hot  47 replies
  • Hot  113 replies
  • Hot  38 replies
  • 3 replies
