Does a WR450 sans starter need the crankcase vent ?
6 replies to this topic
  • MidlifeCrisisGuy
Posted August 23, 2013 - 10:39 AM
I removed the starter on my 2012 WR450. The starter housing has a crankcase vent built into it. Now that I removed the starter, do I need to keep the crankcase vent or can I plug it off ? As far as I know the YZs did not have a crankcase vent, only a valve cover vent. Thanks.
  • MidlifeCrisisGuy
Posted August 23, 2013 - 03:51 PM
The lubrication diagrams for the 2009 YZ450F and the 2012 WR450 look identical. I suspect the starter breather on the WR450 is needed to prevent oil lock or facilitate oil flow to the starter idler gear.
  • fixitandy
Posted August 24, 2013 - 02:16 AM
G'day, I blocked my starter vent on my brand new WR 450 07 the night I bought it home, never had any issues with motor/ trans ever. ROOSTA out.
  • Krannie McKranface
Posted August 24, 2013 - 09:03 PM
That vent is not a 'crank pressure breather' its a 'moisture remover' vent.
  • MidlifeCrisisGuy
Posted August 25, 2013 - 07:47 PM
Why doesn't the moisture vacate via the valve cover ?
I removed the starter and plugged the hole with a frost plug.   It worked perfectly.     I removed the gearcase vent and plugged it off.   I went for a 3 hour ride with no issues.
Posted August 25, 2013 - 08:58 PM
Just don't plug the valve cover breather....or you will get a loud surprise...the valve cover semi-circle gaskets come exploding out the side of the motor in about 15 min.
Not that I would have personal knowledge of this or anything....
  • MidlifeCrisisGuy
Posted August 27, 2013 - 11:00 AM
LOL.  Thanks for sharing that !
