DRZ400S SAG
16 replies to this topic
  • Deman
Posted December 22, 2003 - 11:19 AM
Just returned from setting up the SAG on my DRZ.
What is a good FREE SAG for it?
And what's a good RIDER SAG?
I managed to make the rider sag 95mm
  • kitplummer
Posted December 22, 2003 - 11:22 AM
Depending I what kind of riding you are doing, 95 should be good. Because I am a little harder on my DRZ, I reduced the sag, to compensate for the softness of the spring a little.
Kit
  • Deman
Posted December 22, 2003 - 11:39 AM
kitplummer- How much mm is your FREE SAG?
  • kitplummer
Posted December 22, 2003 - 12:19 PM
I can't remember exactly what it ended up at. Probably around 15mm or so. Maybe somebody else here can confirm the stock free sag setting...
Kit
  • Deman
Posted December 22, 2003 - 08:52 PM
Anybody? What is the free sag supose to be?
  • Spud786
Posted December 22, 2003 - 08:54 PM
10 to 25mm's, after rider sag is set
  • cannondud
Posted December 22, 2003 - 09:06 PM
Mine is 95mm/3.75" with me on it, and 28mm/1" static. That is with the stock spring and I go 215 W/O gear. Rides well at that setting. have not bottomed hard since setting it there.
  • Deman
Posted December 22, 2003 - 09:13 PM
I setted up the rider sag at 95mm but the free sag is 35mm how can I lower the free sag to about 25mm without making the rider sag lower? I cant right? :)
  • rookie517
Posted December 22, 2003 - 09:17 PM
think ya have to change ya spring.
increase the preload will lessen the race sag
  • Deman
Posted December 22, 2003 - 09:19 PM
I doubt I need to change my spring as I wheight only 150lb
  • rookie517
Posted December 22, 2003 - 09:42 PM
i weight about 130lbs, on a 00 S
as i ride sm on the street, i don't really setup the sag so accurately, i just like it soft on the rear.
  • Spud786
Posted December 22, 2003 - 09:46 PM
Your measurements , it sounds like you need a lighter spring, what are your compression settings from full in?
If your bike is new, a little ride time and that spring will probably set more, I wouldn't jump for a lighter spring at this time
  • Deman
Posted December 23, 2003 - 12:58 PM
The compression settings from full in (rider sag) is 95mm
The bike has 10000km on it; not so new :)
  • viverrid
Posted December 23, 2003 - 04:03 PM
Then you probably *do*.
The bike is sprung assuming an "average" weight of around 180 lbs. We all know that the rider weighed 30# more (21)) that he needs a heavier spring. Any wonder that a guy 30# less would need a lighter one? It just doesn't come up as often as most adult males are heavier (esp. w/all the old guys out here!).
Since the bike is kinda soft anyways, a lot of lighter guys can get away with the stock suspension. But really, with too much free sag, because the srping had to be set way light for the race sag, and too heavy a spring for your weight, in theory the bike's geometry wouldn't be right. That's the theory. Its up to your butt whether you need to do anything, but at your weight you can't have both things "right".
Luckily, I weight 175 to 180 so I have never touched my preload setting!
-Vince
  • kitplummer
Posted December 23, 2003 - 05:27 PM
I am at 160...and I am really pushing the limits of the stock setup. I've spent hours trying to set things up with clickers, sag, and extra fluid - waiting for the new year when I can have the local Race Tech set me up. As I've said in other posts, I've stiffened the rear up beyond recommended race sage - to avoid the hard bottoming out that hurts.
It is possible, but if you are serious about riding, no matter what your weight, the DRZ is probably a much better bike with new valves and springs in your suspension.
Kit
  • Deman
Posted December 23, 2003 - 09:05 PM
hmmm... :D or...I can gain about 30lb The holydays are here I got planty of time to eat and spend on the couch :)
  • viverrid
Posted December 24, 2003 - 01:39 AM
hmmm... :) or...I can gain about 30lb
When I started riding, I weighed 115 lbs. and could haul on a Suzuki 90. My bikes sure were light and quick then.... When I got my 360 2-stroke I think I still only weighed 135.
-Vince
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
Drz400E aus spec E and mrd exhaust by GearHeadGumbie
  • 0 replies
Used DRZ400 or DR650? by dnb123
  • Hot  67 replies
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
Suzuki DR-Z400S 2017 by Chris.GVS
  • 0 reviews
