Fix a sticking float in the carb?
3 replies to this topic
  • Freestyle-MX-Racer
Posted August 18, 2013 - 07:58 PM
I picked up an ole' xr80. And the carbs float is sticking. It wiggles around fine and I'd t stuck when the bowls off but it leaks gas out the overflow. I turn the gas off and it still leaks whatever is left in the bowl till its under the overflow. How can I fix this? Anyway to without buying a new floater?
  • Krannie McKranface
Posted August 18, 2013 - 08:06 PM
Remove the float, float pin, and float needle.
Get a flashlight, and look at both the needle (for a groove in the rubber) and the seat (for pitting).
If you see either, you need to replace.
But, most likely, the only problem you have is CORROSION.
Take some brass polish (Brasso) on a rag, and polish the cavity that the float needle slides up inside of.
You need to polish it, and the body of the float needle, so they not longer 'hang up' inside the float needle cavity.
That is usually all that is needed.
It may take 1 minute of polishing, it may take 15, depending on how bad it is.
Do not use any power tools for this.......
Obviously, if  the needle and seat are worn, you then need to replace them.
Posted August 18, 2013 - 09:00 PM
ok thanks! Ill do it tomorrow and post pics.
  • mustangeric
Posted August 26, 2013 - 09:26 AM
i just went through this with one of my xr70. after many failed attemps to fix it by removing and cleaning the carb. i ended up taking the tank off, cleaning it out. When i removed the petcock for inspection i noticed it had dry rotten and was letting trash by that was stoping the needle from setting properly. I removed the stock petcock filter and installed new fuel line and an inline filter. Problem solved.
1993 Honda XR200R bearings kit/list by Jmechler192
Dirt Bike   Make / Model Specific   Honda   XR/CRF 80-200
  • 0 replies
Honda CRF100F 2017 by Chris.GVS
Honda CRF100F 2017
  • 0 reviews
Top speed of xr200r? And xr250r? by LukeSand
Dirt Bike   Make / Model Specific   Honda   XR250/400
  • 12 replies
  • Hot  36 replies
xl100s vs xr100 trans difference? by CarmanCRF
