Need Advice! 09 YZ 450f rear wheel
4 replies to this topic
  • nahu6868
Posted August 16, 2013 - 11:28 AM
I recently broke my hub and sprocket on my 09 yz 450f.  I bought an 06 yz450f used wheel set off ebay without knowing that In 09 yamaha changed the rear hub.  Since im a poor college student i cannot afford to buy a $300 rear wheel.  Could I use
06 yz450f swingarm and connect it to my 09?  Thats cheaper than buying a new wheel! Or if anyone
has any bright idea's where i spend less than $150 i would be grateful!
  • shrubitup
Posted August 16, 2013 - 11:30 AM
rocky mtn sells whole wheel g force for $199 that fits 09
  • JDLowrance
Posted August 16, 2013 - 11:41 AM
Nope. The swingarms are different.
You should probably post this up in the YZ section.
  • beezer
Posted August 16, 2013 - 11:47 AM
Have you tried to fit the wheel?  You should be able to make it work.  I've always swapped rear wheels around between bikes.
  • JDLowrance
Posted August 16, 2013 - 07:17 PM
The 09 YZ uses a 25mm axel diameter and the 06 22mm. Don't care how big your hammer is.
