Frame help!
4 replies to this topic
  • MXTRA
Posted August 14, 2013 - 07:08 AM
Does anyone know if my 2000 YZ 400F parts will bolt on to a 2004 YZ 450F frame? I need a frame and found the 450 available. Looks like it is compatible?
Thanks for any advice!
Posted August 14, 2013 - 08:16 AM
No, the 426 parts will not fit to a steel 450 frame.  The engine actually might as long as you could get the swing arm pivot to fit right, and the suspension will work if you have the 450 swing arm and linkage, but the tank, sub frame, and body parts won't.
  • MXTRA
Posted August 14, 2013 - 10:14 AM
Thank you gray racer! So will up to 2002 work?
Posted August 15, 2013 - 06:18 AM
Yes.
  • cowboyona426
Posted August 15, 2013 - 06:43 AM
I don't know that I'd want to replace the frame on something as rare as a 2000 YZ400F.  It will probably hurt the value.
