Upside down forks on xr650r, worth it?
6 replies to this topic
  • Bmframe
Posted August 11, 2013 - 02:30 AM
Is it really worth the effort to put different shocks on the front of these? other than just the forks what else is involved with switching them over?
  • xios82100
Posted August 11, 2013 - 02:40 AM
you have to replace the triple tree clamp you might need new brake line ,, brake caliper for sure. I put up side down forks on my xr600 from cr250 and they were kinda longer and the bike looked like chopper.
  • MindBlower
Posted August 11, 2013 - 05:23 AM
Not on an R.
 GOOD conventional is as good as USD and the R has good conventional.  Springs and tuning.  ;)
Every other XR? Yes
  • XRandWRRider
Posted August 11, 2013 - 08:34 PM
I thought it was worth it, and several other's here have too.  It doesn't necessarily require a new caliper or brake line, and can be done with a variety of triple clamps / fork tubes.  The 46mm Kayaba USD forks from the earlier CR's are basically an inverted version of the stock fork and while it may flex less, probably isn't worth the work involved.  In my opinion, if you're going to do it, it is worth an upgrade to the 47mm Showa twin chamber forks, or similar... It will require a bit of research, but the threads are here, just do a search.
  • shagger
Posted August 12, 2013 - 12:58 AM
When Honda was racing Baja with the XR they went to USD forks and then went back to conventional forks because the frame worked better with them at high speed off road.
That said. I use USD forks on my supermoto setup. It depends on what you are going to use the bike for.
  • XRandWRRider
Posted August 12, 2013 - 06:37 PM
True...  it all depends what you want.
USD's will flex less and give more precise handling, and are probably better for slower / tighter single track and/or woods riding.
Conventionals will flex and forgive more, and are probably better for the wide open 100 mph blasts through the desert.
Although I enjoy both open desert and tight woods/single track/washes when I ride off-road, I don't race Baja, and truth be told, I should probably pick a lighter bike for the majority of the type of off-road riding that I do.  However, I am a fairly big guy at 6'2" 240 lbs. and I am addicted to the Torque or the big XR's... (Plus, they are already paid for!)  I feel that the USD's help me on both my Dual Sported XRR, and my Supermoto'd XRR.
  • Suspenders
Posted October 07, 2013 - 07:14 AM
Open chamber forks are better suited to trail, rock, and enduro type of riding as they will move with more freedom. Newer closed chamber forks that are on the MX bikes are better suited for the track, jumping, supercross etc. as they will not move through the stroke as readily but are well suited for hard hits such as shorting the double.
  • Hot  35 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 4 replies
  • 22 replies
Honda XR650L 2017
  • 0 reviews
