wr450 clutch much heavier than mates yz250. why?
2 replies to this topic
  • daverw
Posted August 08, 2013 - 09:02 AM
My wr450 has such a heavy/stiff clutch that after a long day riding I pretty much lose all my grip strength in my left hand. I had the clutch case open today to fix a cracked clutch cover so figured I would pull the whole clutch apart for a clean and measure to see if all in spec etc. Its no wonder it takes so much strength to pull the pressure plate has 6 heavy springs to squeeze against. So how come my mate's yz250 has a clutch you can squeeze easily all day with 1 finger?
  • 123devinzz1
Posted August 08, 2013 - 11:25 AM
A freshly lubed cable does wonders on my bike but you still gota use 2 fingers comfortably. I think my clutch basket is getting bad but il let it be. Thinkn about putting a rekluse in later on
  • Krannie McKranface
Posted August 08, 2013 - 12:15 PM
Too many variables to define exactly what it is.
Usually, it is a worn clutch lever and cable (binding, lost leverage) or a worn clutch basket.
Simple carbon build up in the oil can make the clutch stiffer.
