carburetor install
10 replies to this topic
  • step655
Posted August 04, 2013 - 04:37 PM
I took my sub frame off and rear shock off
I got the carb on to the intake boot on the engine but I can't seem to get it on the air box
What are the tricks ???
Thanks n advance
  • step655
Posted August 04, 2013 - 04:39 PM
2007 wr450 btw
  • 123devinzz1
Posted August 04, 2013 - 05:07 PM
keep the shock off. put top subframe bolt on then swing down the subframe and slip it on the carb. loosly thread in bottom left subframe bolt, tighten up the boot on the carb. At this point you should be able to fit the shock in from the right side. Install right subframe bolt. then tighten everything up.
  • step655
Posted August 04, 2013 - 09:04 PM
Thank you
  • kawi380
Posted August 05, 2013 - 05:46 AM
Normally when I do this I leave the boot attached to the airbox and swing it out of the way with the subframe.  When reinstalling you just have to squeeze the boot around the shock and it usually slips onto the carb with not much fuss.
Here is a pic with the subframe rotated out of the way and the boot still installed on the airbox.
  • 123devinzz1
Posted August 05, 2013 - 06:12 AM
I done same thing by tilting subframe up. Dont have to mess with wiring and the battery. I had alot of trouble getting it on with the shock there. It would slightly bend the clamp when squeezing it through and i couldnt get my hands in to fix. I found that keeping the shock out was the way to do it.
Posted August 05, 2013 - 06:43 AM
I find it easiest (on an aluminum YZ450) to unbolt the air box from the sub frame, slide the sub back off the box, then unclamp the air box from the carb.  On reassembly, I slip the air box on the carb first and clamp it, then slip the sub frame back on.  The tail lamp harness may complicate the matter on a WR by limiting the amount the sub can move rearward without disconnecting it.
If the boot still gives you fits using the swing-on-the-top-bolt method, try leaving the carb free of the head until after you get it clamped into the boot (leave the lower sub frame bolts out during this), then plug it into the mounting sleeve on the head.
  • beezer
Posted August 05, 2013 - 07:01 AM
WD-40 on the inside of the boot helps.
  • GreenHornet450
Posted August 05, 2013 - 07:12 AM
Silicone. Wet Tire Spray on the inside of boot. Works everytime.
  • step655
Posted August 05, 2013 - 07:42 AM
Got her on :D
  • Road Rage
Posted August 06, 2013 - 01:10 PM
Yeah it's definitley an experience and repetition thing, by the time you do it 5 or 6 times it will become easy with the swinging down of the subframe...most times it just seems to pop into place now.
