Head Gasket, Idiot Alert!
4 replies to this topic
  • WRob
Posted August 04, 2013 - 08:01 AM
06 WR450 top end job.  After meticulously following the manuals instructions for torquing the head, I realized I had forgotten to install the front timing chain guide. :banghead:  IDIOT!  Back off with the head.  Now, did I pretty much ruin my new head gasket?  I torqued it completely per the manuals instructions ( 20 ft lbs--then 180 degrees in stages...)  Give it to me straight Doc....Thanks in advance
Edited by WRob, August 04, 2013 - 01:39 PM.
  • highmarker
Posted August 04, 2013 - 09:32 AM
been there done that,  got lucky with the gasket, inspect it good and maybe use some spray copper on it.
  • monkey jason
Posted August 04, 2013 - 09:59 AM
The old 490 2 stroke head gaskets you could put in the oven for a bit, I don't know about the 450 4 strokes.
  • highmarker
Posted August 04, 2013 - 10:32 AM
the 4t gaskets are usually multi layered and use a graphite type coating. If the graphite peals away stuck to the gasket surfaces it's pretty much toast on a head gasket.  On a side case, if you DONT scrape any of the material away and put it back in the same place with some goop you can usually reuse.
  • JDLowrance
Posted August 04, 2013 - 11:06 AM
Why chance it? Chock it up to experience and get a new head gasket.
