Help needed
3 replies to this topic
  • 2359cliff
Posted July 29, 2013 - 11:27 AM
When racing the bike seems to not quite return to idle after accelerating coming into corners so leaving me with no engine braking, cables are free and bike returns to idle as normal when stationary, have checked for air leaks around carb(all fine) could it be TPS ?
  • vlxjim
Posted July 29, 2013 - 01:10 PM
What Map are you running? You may need to lean it out a little on the low side. Check that your idle is less than 2000 rpm. I run mine at 1920-1940 or so.
My bad I though it was a FI bike.
Edited by vlxjim, July 29, 2013 - 08:48 PM.
  • Krannie McKranface
Posted July 29, 2013 - 07:17 PM
http://www.thumperta...o-eliminate-it/
  • Thommo_400f
Posted July 30, 2013 - 03:00 AM
Hanging idle is very common. Set your pilot system correctly and it will go away.
