2012 WR450F Modify Shock to Shrader Valve?
4 replies to this topic
  • mch
Posted July 29, 2013 - 07:56 AM
I just pulled my shock for the 1st time and just noticed the shock uses a needle valve to recharge the shock with nitrogen. I was presed for time, so I had my GF's son take the shock to a local shop for service (I would have done it myself if it was a shrader type valve), So I really have no idea what's inside it. I'm assuming a standard bladder, and I'm assuming there are other motorcycles that use the same housing, but with a cap that has the shrader valve.
That being said, anyone have any ideas to convert it to the shrader valve type for future services? Anyone see any cons to doing this? Seems like there is more than ample room for the valvle to fit. If I want to just do a standard nitrogen recharge, it looks like it would be pretty straight forward with the shrader valve being a lot more accessible than the needle valve.
  • JDLowrance
Posted July 29, 2013 - 11:16 AM
Most aftermarket suspension shops install schraders when they tune your suspension. The resivoir cap has to be removed to drill and tap to facilitate the schrader valve.
  • GuyGraham
Posted July 31, 2013 - 11:36 AM
Its just a self sealing rubber bung in the centre of the cap, with a normal bladder
As said above, the cap needs drilling and tapping to accept a schrader valve.
Its not that different to what you are used to
with no nitrogen in the bladder, you can push the rubber bung out if your charge needle is blunt
Motion pro do a needle for about $21 if you dont want to mod your shock
http://www.motionpro...partno/08-0075/
  • WR 911
Posted July 31, 2013 - 03:05 PM
The 2012 shock specs are the same as the previous model WR. Therefore order a schrader valve type bladder cap from any after market company like SDI.
  • mch
Posted August 01, 2013 - 09:10 AM
Thanks all.
