Trouble with motor- YZ400f
1 reply to this topic
  • MT400f
Posted July 25, 2013 - 04:42 PM
Hello,
I recently bought a 1998 400f from a guy who couldn't get it to run. A quick carb clean and rebuild and some gas made it run great. I put probably about six hours on it after that.
On my last ride I started it and was riding for about 30 seconds and just as I was getting ready to stop and check the oil it sort of bogged like I had forgotten to turn on the gas. It died and then started a few times before seeming to seize up (kick start was rigid). There was plenty of oil and coolant.
The motor will turn over with a socket on the crankshaft, albeit not smoothly and with a grinding/scraping noise. I drained the oil and there were significant metal shavings in the oil filter housing. I popped off the valve cover and the camchain seemed to be intact.
I believe the bottom end is okay (can turn back wheel over by hand in all gears with clutch lever in).
I know I need to start opening it up and getting to the bottom of it but do these symptoms indicate anything in particular to look for?
Thanks,
Justin
Posted July 25, 2013 - 06:24 PM
No, nothing in particular. Check the condition of the oil pump while you're there, though.
Motocross
  • Hot  491 replies
  • Hot  36 replies
  • 10 replies
