Stumped by 2004 YZ450F
No replies to this topic
  • rcv450f
Posted July 24, 2013 - 06:09 PM
I need help with this pain in the ass bike that will not produce a spark. Below is the list of parts that have been replaced.
a) Stator - ohm values check with book
B) CDI
c) Ignition coil
Kill switch and neutral switch work, new wiring harness, and good ground connection.
The CDI is a used unit but before I order a new one I want to make sure the stator is working properly. Like I said ohm readings on stator are per the book and would ilke to test voltages coming out of the coils on the stator. Any ideas of what voltage ranges I should be getting on the 2004 model? A fluke meter with peak reading capabilities will be used. Since these are peak readings I assume VDC should work fine or should I set the meter to VAC?
  • Hot  28 replies
  • Hot  36 replies
  • Hot  30 replies
  • Hot  113 replies
  • On January 15, 2017
