2008 WR450F WITH YZ SUSPENSION AND CAMS / PART DEUX
Yamaha YZ450F 2008
132 replies to this topic
  • Krannie McKranface
Posted July 26, 2013 - 05:55 PM
#21
Oh no you don't get out of this that easy. You could always drill the hole or have it drilled through. :rolleyes:
My Dad has a bitchin' set of tools. I can fix it.
  • stevethe
Posted July 26, 2013 - 06:17 PM
#22
If he's got drool bits your in. Jump on it Kawi man.
Edited by stevethe, July 26, 2013 - 06:53 PM.
Posted July 26, 2013 - 08:03 PM
#23
  • stevethe
Posted July 27, 2013 - 05:35 AM
#24
https://www.youtube....h?v=A5cneCgNA9U
Very nice!
  • gcally
Posted August 12, 2013 - 09:30 AM
#25
Any updates?
Posted August 12, 2013 - 09:58 AM
#26
Any updates?
Yes.
Hot Cams YZ cams work best with a HC piston and some porting, which I don't have.
The motor is PERFECT for supermoto, but the power comes on too late and too strong for casual trail riding.
It's fine if you keep it above 6 k rpm for acceleration, or below 5k for grunting around. It's just that theres no acceleration to speak of down there.
The stock header works MUCH better than the YZ header, with low end power delivery, and no change on top.
My vavle train has suddenly become very noisy, so I have to back inside....
Posted September 03, 2013 - 06:13 PM
#27
The head comes off this week for porting.
The overall concensus by the dozen or so tuners I talked to is "the Yamaha heads are all different, and all restrictive. Port it or be un-happy"
So, since I want to be happy, I shall port.
And polish.
  • KennyMc
Posted September 04, 2013 - 05:49 AM
#28
And polish.
Do it man, just do it! :-). Let me know what, if any, jetting changes they recommend after the porting. I know you know mine but if AS isn't doing it, don't tell whoever is. It would be interesting to see what there recommendation would be.
Posted September 04, 2013 - 07:03 AM
#29
Porting should have no effect on jetting, but to possibly allow you to run a larger main without side effects.
  • KennyMc
Posted September 04, 2013 - 04:41 PM
#30
I was just saying that if whoever does the porting suggests a jetting change to post up what they suggested if anything.  I wasn't saying to make a change.
Posted September 04, 2013 - 06:08 PM
#31
Oh, of course, I will dial it in and report back.
I expect big things, as the 450X has similar issues with I added a cam to it (though not as severe): very stage-y power.
Posted September 05, 2013 - 06:41 AM
#32
Head will be off shortly.....
Posted September 07, 2013 - 12:29 PM
#33
Head is off.
It's running way to rich, just like I thought, but leaner needles did not help.
  • shrubitup
Posted September 07, 2013 - 01:24 PM
#34
nice needle jet tuning. Honda CR250 carbs from 01-03 also were tuned similarly no a needle jet DO make a difference.
Posted September 07, 2013 - 02:05 PM
#35
..don't understand what you are saying...this is not a two stroke CR....?!
  • shrubitup
Posted September 07, 2013 - 03:05 PM
#36
Yes, I'm aware of this. Just pointing out the similarity. Most two strokes don't have needle jets to tune either. Glad you found a way to improve it.
Posted September 07, 2013 - 03:52 PM
#37
Oooohhh, needle jet.
Yeah,  will porting will solve EVERYTHING, or else....
  • PBDBLUE
Posted September 11, 2013 - 06:42 AM
#38
Head is off.
Plug certainly doesn't look rich...
Posted September 13, 2013 - 03:38 PM
#39
OK, getting a bit closer.
The  center intake port is notoriously very small and oddly shaped. You can't even get your finger down inside it like you can the other ports.
Well, now you can....the shape has been corrected for laminar flow, and the diameter changed to be linear. Can't give too much of the 'secrets' away here....
Again, without giving too much away, the front of the intake has been changed so the intake volume is more closely matched to the exhaust port volume, and has been changed from square to oval shape... sorry, can't find the 'before' pics anymore....
Posted September 17, 2013 - 08:44 AM
#40
HEAD IS FINISHED!
1236716_10200681478659586_640779056_n_zp
BEAD BLASTED AND PORTED INTAKE
999761_10200681488859841_1656129212_n_zp
POLISHED AND PORTED EXHAUST
551144_10200681474459481_1787908149_n_zp
YZ 450F Performance upgrades? by riderboy1961
  • Hot  37 replies
2008 YZ450f suddenly dies by MotoFixation
  • 4 replies
Yamaha YZ450F 2008 by ThumperTalk
Yamaha YZ450F 2008
  • 23 reviews
  • Last review by Metzman
  • On December 11, 2016
