Race Tech Gold Valves?
33 replies to this topic
  • PaulP
Posted December 08, 2001 - 06:09 AM
One of my riding buddies has a set of Gold valves that were originally for a 99 YZ125 and according to RT they will work fine in his new 01 YZ426. He was wondering how others that installed the Gold Valves like them? Any shim stack recommendations other than what RT recommends?
There has been some opinions posted here that suggest that the srock KYB pistons are actually superior to the older RT designs, so anyone have any suggested shim stacks (mainly high speed) for the stock forks? The forks are new (4-5 rides) so the mid-valve shouldn't be a problem at this point.
The easiest thing would be for him to simply ship the suspension off to a reputable shop for a revalve, but he really wants to try it himself.
He is a Vet Expert rider. The springs are stock.
Thanks,
PaulP
  • Paul_Thistle
Posted December 08, 2001 - 03:33 PM
No the new KYB valves are not better than the RT( my opinion, based on comparing them side by side). Call to get valve specs and then go down 2 steps softer on hs comp front and back. Be sure to take out the mid valve and install the RT cartridge seal or cylinder valve seal as they call it.PT
  • motoman393
Posted December 09, 2001 - 05:32 AM
Good Luck on installing the gold valves! I installed mine about 3wks ago (I havent ridden it yet due to injury and rain this weekend, arghhh!)
If your friend is doing this himself tell him to check this site out: http://mx393.tripod.com/tech.html and look under the
"Supension section" I have posted a few helpful hints, so that the "average" weekend warrior can install the gold valves w/o all the $60-70 tools from Race Tech!
CLICK HERE to see the setup I am running!
MXTuner who is a suspension guru (who visits this site) recommended this valve stack CL5, CH2 in the forks. He can tell you more if you are interested!
Whenever I get to test out my suspension I will post the results. Because I have gotten lots of emails asking how it is working in comparison to stock? Later,
Garrett
  • PaulP
Posted December 09, 2001 - 06:32 AM
Thanks for your input guys. I'm am surprised that only two have responded regarding the gold valves...I woulda thought that more guys would have tried them them.
Thanks,
PaulP
  • Guest_Guest_*
Posted December 09, 2001 - 08:14 AM
I had bought my 400 in early 00' and thought the suspension sucked! I came off of a 95 250 that had the gold valves so i was spoiled, but thought the tech in 4yrs shud have been equal even stock!
Not the case. I bought the front and rear gold valves and also went to 47 fork springs. I had my susp guy valve super soft. triple valved (I think he said) and the 47's would take any huge hit and keep it from bottoming. Works pretty damn good. Although I would like to try a little softer spring in the front just for giggles.
It was like riding a cadilac across the DEZ instead of a tractor!
$.02 :)
  • MX_Tuner
Posted December 09, 2001 - 08:51 AM
There are more than a few Gold Valve users around. I'm not aware of anyone who isn't quite pleases with them (who has them properly set up). I am continually impressed with their performance everytime I ride on them. I rode GA426Owners YZ again yesterday. I installed the GV's and am amazed at how well the bike works. You can come up short, get squirrely and all out of shape and the bike jsut soaks up every bit of it. Nice and plush over sharp edged bumps with great bottoming resistance. This is with the mid-valves disables and the cylinder valve block off plates installed using the Type One Gold Valves with a two stage stack up front and a three stage stack in back.
Until I find something better, I'm sticking with recommending Gold Valves.
  • Taffy
Posted December 09, 2001 - 01:32 PM
if anyone in GB wants to P/EX with my gold valved forks give me a call. my bike is going and i want to turn things into cash.
one of the best things i did if not thee best. i've had the rear shock done as well. both to suit 14 stone rider (196lb).
Taffy
  • DaveJ
Posted December 10, 2001 - 01:38 PM
Perhaps we need to clear a few things up.
When you purchase the Race-Tech Gold Valves, you get a kit. Inside the kit are the valves themselves, and a collection of valve shims.
When you make the modification per instructions, you are removing the factory valve, and modifying the number and types of shims that KYB put in at the factory.
Upon your test ride, you conclude the forks work better. Therefore, you conclude, the Gold Valves are superior. However, was the improvement the change in the valve, or the change in the shims?
The next question would be, what if you modified your forks, changing only the valve stack, therefore keeping the factory valve?
Would the ride be just as good, better, or worse?
More importantly, the question should be, what is wrong with the factory valve that warrants replacing it? And what makes the Race-Tech design better?
What I personally care about is finding out what constitutes the best valve, then what is the right collection of valve shims to go with the valve I have chosen, based on my needs for the type of riding that I am doing.
If I wanted a brain-less fix, I would get the Race-Tech valve kit. It’s nearly full proof. Choosing the type of ride that is needed is as easy as selecting a valve stack number, such as CL2 and CH5. Race-Tech makes their money by making it that easy.
Now back to the question of what is the better valve, Race-Tech or the factory KYB?
The most important consideration in a valve design is consistency of resistance. Meaning, that the valve should be able to smoothly flow oil regardless of how much oil is being forced upon the valve. In other words, there should never be turbulence. The valve has to flow oil without any drag.
In fluid dynamics, this usually means the most direct and smoothest path. Oil that has to flow over and around sharp edges and corners causes the oil to drag in its route. In a poorly designed valve, this essentially means the oil is headed back in the opposite direction by the time it gets to the valve stack.
One way of fixing the drag problem is making the holes of the valves bigger. This is what Race-Tech has done. The other way, is to construct a valve that has less turns and sharp corners. This is what KYB has done.
Either valve with the wrong set of shims will yield a poor ride, and vice versa.
Does the average rider that dares to open his or her forks know what changes to make to the shim stack to better control front wheel movement? Of course not. Neither do most of the people working in the suspension shops that modify your forks. This is why there are Race-Tech valving kits and franchises. Someone comes up with a design that works, and sells that knowledge in a package to others. It’s nothing but smart business.
So back to the subject. In late model forks, KYB, without a doubt, makes a better valve. Race-Tech, without a doubt, has the best do-it-yourself service. Included with that great service, is a well designed new valve.
DaveJ
  • John_Curea
Posted December 10, 2001 - 05:29 PM
Davej
As always, a very interesting reply...
I agree, for a do-it-yourselfer approach to doing suspension, race tech has simplified the process. From a marketing stand point, there goal was this:
Put together a method of revalving the stock suspension on a motorcycle which will deliver an improvement, yet be simplistic enough for the average mechanic to perform.
Again, I believe they succeeded in making an improvement, because a rider can dial his forks closer than the "catch all" stock valving.
Unfortunately, I believe that they have traded performance for simplicity to some extent.
Designing and installing a properly tuned midvalve compression shim stack in the fork can get pretty complicated. When we start getting into pivot points, float settings, and stack build variables, and to figure a way to make this work in conjunction with the base valve in a favorable manner is quite a task.
Even the mechanics of the build process is more complicated than the base valve assembly.
The end result is that the added performance of a properly tuned midvalve is better than a check plate.
If you think about it, midvalve shim stacks (active valving) are the industry standard. This is true in production and in the racing enviroment. One of the few bikes out there that doesnt have a midvalve installed from the factory is the DRZ, it uses a check plate.
Every major motorcycle suspension company, KYB, Showa, WP, Ohlins subscribes to the midvalve philosophy.
Then why we ask, if this is all true, then why can we make the race tech version perform better than stock? Do they know something that the suspension manufacturers dont know?
Motorcycles at an industry level are built and designed with everybody in mind. In other words, they have to build a bike that "everybody" is going to be "ok" with. A tough job , no doubt.
The majority of motocross bikes sold will never see a motocross race. The bike will be sold to all different types of riders, abilities, and riding conditions.
To valve for all of these conditions is difficult, the manufactures must create a suspension setting that they think will make everybody happy. Of course there is a lot of trade-offs with this design, but they really have no chioce.
I beleive that the manufactures do a really good job of valving the motorcycle in respect of how many different levels of riders will ride the bikes.
I now I am getting a little long in the tooth here, but yes, the race tech design will get a rider closer to his abilities/riding conditions than a stock set up.
But, can we get even better results? Absolutely.
You want to try something interesting?
The face shim on a stock KYB is 24mm, the stock face shim on a RT piston is 22mm.
Find a good RT stack build, use the STOCK KYB piston, add 2mm to every shim in the base valve build and toss the midvalve, throw in a check plate and go for a ride. You will end up with what I call the "poor mans" gold valve :)
The reality of it is that the flow patterns of a RT valve and that of a stock valve are very similar. Why do you think RT went with a 22mm face shim? They didnt want everybody using there stack reccomendations on stock pistons.
The industry standard for a 28mm base valve is a 24mm face shim. The larger the face shim, the more low speed control we can maintain.
The stock ports are not restrictive and do not create drag. Port size has more to do with the "speed" of the fluid traveling through the valve (Bernoulli's Principle).
If you think about it, the most fluid that will flow through a base valve is equal to the area of the piston rod that is in the cartridge at any given moment. We also have to subtract the amount of fluid that has gone through the clicker and also the fluid that goes through the cylinder valve (providing we havent removed it).
The average piston rod is 12mm (WP is 14mm) multiply this times the length of the rod that is in the cartridge and that is how much fluid is being displaced. The max is around 2 or 3 ounces ( I have the exact figures someplace around here) The point is, that there is not that much fluid moving through the base valve, especially not enough to cause any drag or resistence (for practical purposes that is).
Well, thats it for now, I am sure we are into another great TT suspension discussion!! :D
Take Care, John
  • Paul_Thistle
Posted December 10, 2001 - 07:12 PM
So John, If the port area on the RT valve is greater will it flow more oil faster, thereby allowing you to gain better control of the oil using the valve stack (since we are unable at this time to manipulate port orifice size)?
What difference does a smaller diameter shim make? Since the ports are the same dia. and the oil is pushing at the same point on the shim. The fulcrum to load and shim thickness coeff. are identical. So I guess the only advantage would be more clearance around the shims themselves. To take better advantage of the larger ports?
Oh yeah, the RT valves are better than the stock valves. But the stock ones are the most lethal ammo in the old slingshot yet.PT
  • John_Curea
Posted December 10, 2001 - 07:33 PM
Paul
You have that backwards, as the port size gets smaller , the velocity of the fluid increases, and vice versa.
Shim diameter is everything, think of this in respect to leverage. The further outward away from the center that we move the point at which the oil is exerting pressure on the shim, the more we can control how that shim deflects.
The closer to the center and we are narrowing down the effective range of control.
This is getting pretty involves and we will eloborate more in the morning.
As far as the stock valves being lethal ammo, theres this cat that keeps getting in my trash...hmmmmm.!! :)
Take Care, John
  • thumpy
Posted December 10, 2001 - 08:19 PM
What the.......who......where........orafice....velocity times stack divided big macs :)
Let's simplify this for a moment shall we, if you guys are gonna argue, you're gonna have to do it in english....sheesh :D
Any comments on the Enzo (J&M) subtank dumaflechies. If so, what kind of valving works best with this type of set up?
  • MX_Tuner
Posted December 11, 2001 - 08:01 AM
Basically what it boils down to is most people can get a HUGE improvement from RT Gold Valves. A few (and I mean VERY few) can improve over the GV performance without MUCH trial and error. Especially since suspension action is so subjective. What one guy likes, the next might find much too harsh. For my purposes, I get outstanding results virtually the first time every time with Gold Valves.
I've tried other valving, other pistons, other set ups and still have not found anything to work as well as Gold Valves. Is it possible to get better performance than Gold Valves can deliver? I'm sure it is, but I haven't been able to figure out how with anything I've ever tried. I've consulted other professionals over and over and still haven't come up with anything yet. Am I done trying other things? Nope, not on your life!
  • DaveJ
Posted December 11, 2001 - 08:47 AM
I think that about concludes it...right?
If I understand everyone, it's really a matter of preference, and the desire to want to work with your options.
Did we miss anything?
DaveJ
  • Ga426owner
Posted December 11, 2001 - 09:49 AM
Yep we missed something. The stock KYB valving & shim stack work very well for the beginner to novice rider. As I progressed in my own riding ability the stock KYB fork & internals seemed to change from good to harsh/bottoming at all levels of compression dampning. Even people watching me or taking pictures noticed the effects of the fork constantly bottoming. I sure noticed how painful landings occurred as well as braking bumps. After the gold valves were installed w/ midvalve removed the fork range of compression dampning was vastly improved & in most every part of the stroke -- the fork acted very smooth with very little harshness in action as well as smoother bottoming resistance. The bottom line is this: my confidence has increased. Last weekend at the local race track I was hitting jumps with total confidence in the forks ability to work as I expect them to. I am a happy Goldvalve customer.
  • DaveJ
Posted December 11, 2001 - 10:46 PM
That would be a different subject, and still one of controversy.
I think the issue of bottoming and inconsistencies in stroke performance are the fault and failures of the mid-valve and cylinder valve. Both of which you modified during the course of installing the Gold Valves.
You essentially changed three factors so be careful which one you draw your conclusion to.
In my little world, the integrity associated with the design of the KYB mid-valve warrants it's removal. And the very same applies to the cylinder valve. When one of the other fails, the fork collapses.
Both can be modified, but I was never able to find a modification that could withstand continual abuse, (trail and woods riders need not worry). So out they went.
And...here we go again.
DaveJ
  • Paul_Thistle
Posted December 11, 2001 - 03:00 PM
Orafice=Hole
When your forks move they try to force oil through these holes real fast.
If the hole ain't big enough you feel a jolt through the bars. You know that time you hit that sharp bump and it "FELT" like the forks bottomed BUT the wheel wasn't all the way up????
Thats what happens when the hole isn't big enough.
Some people preach "control the oil with hole size" while others worship the "shim stack" ALL BE SILENT BEFORE THE STACK!!
My experience has been use a valve that will flow enough oil for your application then use the shims to give the desired feel.
And remember if you can't get the oil through the hole, you can't control it with the shims.
And John both valves push on the shim at the same distance from center, so the leverage ratio is the same. If it were a wrench and you had one 2" long and one 10" long. If you push on both wrenches at 2" out from the fastener there will be no advantage or disadvantage using the long wrench. Don't make me get out the crayons!PT
  • MX_Tuner
Posted December 11, 2001 - 04:20 PM
Dave, good point about what accomplished what. I've done plenty of GV's with and without the mid-valve and cylinder valve mods. The Gold Valves *do* make a huge difference, regardless of other mods. RT's recommendations on valve stacks are dependent on whether the mods are done or not.
I can't ride Ga426Owners bike. I start getting way to over-confident and start getting tempted to jump stuff I shouldn't. I don't want my mind to write checks my body can't pay for.
  • PaulP
Posted December 11, 2001 - 04:38 PM
Boy did this turn into a thread or what!?! :) I am constantly amazed at the amount of information that is exchanged on this board...gotta love it. And thank you all for the replies. It's obvious that there are lots of ways to address suspension tuning and as was stated above...there is prob more than one "correct" way of attacking it.
When my riding buddy asked me to post this question about the gold valves and recommended valving I had no idea that it would turn into the excellent thread that it has. I love the suspension threads anyway cause I get so much out of them myself. Thanks guys.
PaulP
  • John_Curea
Posted December 11, 2001 - 04:46 PM
Paul
Thats it , I am breaking out the crayons, construction paper, legos, lincoln logs, and whatever else it takes....!!!LOL!!!
You sound pretty fired up, but I am going to have to take some air outa yer sails....!!
The first commnent you made:
"If the hole ain't big enough you feel a jolt through the bars. You know that time you hit that sharp bump and it "FELT" like the forks bottomed BUT the wheel wasn't all the way up????"
*are you sure the last 4 letters of your last name arent "eade"??!!!! LOL!!
Anyways,...The situation you are referring to would be a " hydraulic lock" (this happens when port size isnt enough to handle the fluid attempting to flow through it). Realistically, , the valve that we use has ports that are smaller than stock and we dont even come close to a hydraulic lock situation. I can build a shim stack that can be very supple and use the entire stroke without "spiking" anywhere.
Also, and this is a big one, do you really think that the engineers at Kayaba would actually build a valve that would cause a hydraulic lock situation because the ports couldnt handle the fluid flow? We are talking about one of the very elementary concerns as far as valve design goes.
And the present KYB piston has been around for years, in Kawasakis and Yamahas, this is not a first year item.
To back this point up, one of the main complaints with a stock KYB fork after a period of time on it is that the fork blows right through the stroke, not spiking. As GA426 was describing how his forks were behaving.
And also....the point you made about the stock KYB piston and the RT piston exerting pressure at the same point on the face shim from center.
If you measure a stock KYB piston, the distance from outside to outside of the port is 23mm, on the RT valve, the distance from outside of each port is 20mm. The stock KYB piston port is 1.5mm further from center than the RT piston.
I dont care what color yer crayons are pardner, thats a whole different leverage ratio. :) :D
Take Care and have fun.....John
  • Hot  28 replies
  • Hot  47 replies
  • Hot  30 replies
