99 yz 125 no spark
22 replies to this topic
  • yz125_99
Posted July 18, 2013 - 12:18 PM
Hello, I am new to this forum and would like to try to figure out what is wrong with my (semi) newly acquired bike. I bought the bike about 2 months ago and up to now it has run perfect, about two weeks ago though it started acting up. I had just gotten home from a weeks vacation and wanted to go riding but the bike wouldn't start, I thought this was very odd as i had just ridden it the week prior to when I had been gone. I got a new plug for it figuring that it was just flooded, stuck it in and still wouldn't go. That is when i decided to check for spark, and sure enough there wasn't any. I have already checked the grounds and cleaned out the cap connection, as well as ruling out a bad kill switch. Now I am quite confused as to what would be causing this? Is there a way to test the coil? I am pretty handy so I would like to try to fix this myself if i can! Any help would be greatly appreciated!!
  • Mx Factory USA
Posted July 18, 2013 - 04:49 PM
First pull the cap off the coil and cut the wire back a half inch, screw the plug back on the wire and give it a go. If still no spark get yourself a manual and multimeter. Check resistance on the coil and stator. If those check out fine replace CDI.
  • yz125_99
Posted July 18, 2013 - 06:07 PM
Will do! Thanks!
  • yz125_99
Posted July 20, 2013 - 07:48 PM
So I finally got out to the garage again today and cut the cap back. I am not sure if I tested the coil with the right procedure though, I took put one point in the cap and one on the coil where the wire connects, I didn't get a reading though? I just find it weird that the bike just suddenly won't start?
  • 1fastbadA
Posted July 20, 2013 - 08:06 PM
  • service manual use it religiously
  • yz125_99
Posted July 20, 2013 - 08:45 PM
I was able to find the reading numbers by doing a Google search, I was hoping someone knew the procedure for testing the coil/stator.
  • Likemike_Lilshawn
Posted July 21, 2013 - 12:25 AM
I'll trade mi bike for your yz
  • Polar_Bus
Posted July 21, 2013 - 03:31 AM
Not sure what you mean when you say "I didn't get a reading" ? Are you using a ohm meter ? Do you have the ohm meter set to the correct scale ? (should be "1", but some digital meters are self sensing) Might be a good idea to take the coil to your local Yammi dealer and the service dept can check it for you.
  • yz125_99
Posted July 21, 2013 - 05:10 AM
Yes I have the right meter and it was set to 1, maybe that is what I will wind up doing although I would like to rule out the stator too if I can.
  • Fast_Eddie
Posted July 21, 2013 - 05:30 AM
replace the spark plug cap with an NGK. It's worth the $8.00 just to rule it out. Some YZ's it that era had fussy caps.
  • yz125_99
Posted July 21, 2013 - 09:11 AM
Would I have to order that online or could I get it from a parts store?
  • yz125_99
Posted July 22, 2013 - 12:54 PM
So I got my coil trested at my local dealer today and it is not the problem, I also picked up a cap on the way home. Put it back together and still no spark! Stator?
  • Fast_Eddie
Posted July 22, 2013 - 03:37 PM
If you have disconnected the kill switch and ruled out wiring then you're only left with Stator and CDI. I've never heard of anybody needing a CDI on a YZ. I have burned out a couple stators over the years on other bikes. If you did need a CDI that might be available from dirtbike junkyard that is always parting stuff on Ebay.
  • yz125_99
Posted July 22, 2013 - 03:45 PM
Is there any way to test a stator?
  • Mx Factory USA
Posted July 22, 2013 - 09:04 PM
Pick up coil res use + test lead on white/red lead and - test lead on white/blue lead for 248-372 ohms (100 ohm scale)
Source coil 1 res use + test lead on black/red lead and - test lead on green/white lead for 720-1080 ohm (100 ohm scale)
Source 2 coil res use + test lead on green/blue lead and - test lead on black lead for 44-66 ohm (10 ohm scale)
  • yz125_99
Posted July 23, 2013 - 07:54 AM
Thanks! That is exactly what I was looking for!
  • yz125_99
Posted August 05, 2013 - 02:22 PM
So I found out my stator was bad, I purchased a brand new one off of EBay for a great price and got the bike running. I also found out from my dealer that it is actually a 98 instead of a 99. Now I have a new problem, the bike idles slower than before and it seems to run different, more "pops" and crackles in the exhaust note. I took it out for a test ride and right away it just started bogging after I got to 1/2-3/4 throttle! Only other thing I did was clean the air filter and re-install...any ideas?
  • Fast_Eddie
Posted August 06, 2013 - 06:32 AM
Rebuild the carb and clean out all passages, then remove the upper power-valve cover and spray it out with brake cleaner or WD40 if goo is holding it closed.
  • yz125_99
Posted August 16, 2013 - 04:09 PM
Any tips with timing? I did read the "250 timing thread" and got some good tips but the timing marks looked different than on my 125. Any help would be greatly appreciated!
  • Mx Factory USA
Posted August 18, 2013 - 09:20 AM
This thread will help you
http://www.thumperta...gnition-timing/
What would you buy? by 2000YZ250
  • Hot  45 replies
Yamaha YZ85 2016 by Chris.GVS
Yamaha YZ85 2016
  • 0 reviews
yz250 dies above 1/4 throttle- i'm out of ideas! by CaseMoe
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • Hot  35 replies
Wiseco crank? Are they good by twostroke-notbroke
  • Hot  47 replies
How low can a dirt bike be lowered? by Numsa Hul
  • 11 replies
