Broke main jet off in main nozzle, help!
5 replies to this topic
  • mcpga
Posted July 15, 2013 - 01:47 PM
I was attempting to change the main jet in my 03 wr450 thru the hole in bottom of the carb, but I accidentally over tightened it and broke it off in the main nozzle. Can I unscrew and replace the main nozzle without removing the carb? If so, does anyone know what size socket to use?
  • 123devinzz1
Posted July 15, 2013 - 01:59 PM
Pick yourself up some gra-bits (stripped screw extractor) and give it a try.
  • Do I Care?
Posted July 15, 2013 - 06:00 PM
The main jet should be 8mm.
Use an extractor as mentioned above or just buy the main nozzle for around $20.00.
  • mcpga
Posted July 15, 2013 - 06:34 PM
Yes I'm going to buy a new nozzle along with a new main jet, thank you...
Edited by mcpga, July 15, 2013 - 06:57 PM.
  • mcpga
Posted July 15, 2013 - 06:56 PM
Thanks Barra8, 8mm socket took the main nozzle right out and a small Phillips head screw driver easily removed the broken piece of main jet, re-installed everything. The whole process took 5 minutes, so glad I didn't have to remove the carb. Thanks again!
  • Do I Care?
Posted July 15, 2013 - 06:59 PM
No drama's :thumbsup:
Enjoy!
