2009 YZ450 weird starting bugs
2 replies to this topic
  • shrubitup
Posted July 14, 2013 - 10:41 AM
Sometimes when I kick it the kicker won't budge at all. Feels like it needs a compression release. I put it in gear and roll it fwd and no improvement. I just power through it with my leg and finally it moves and problem gone. Sometimes there's very little compression like a release is stuck open. I cycle through the kicker until it finally has compression (about five kicks later). Bike is low hour and when cold/warm it reliably fires first kick but like a two stroke (small throttle blip when starting). Problem occurs when hot. Is something wrong with my exhaust cam automatic compression release?
Posted July 14, 2013 - 03:48 PM
It happens. Has to do with the auto decompression mechanism. Unless you have an auto clutch like a Rekluse, you can normally put the bike in gear and pull it back a couple inches to free the engine up an re-engage the AD unit. Read:
http://www.thumperta...763#post9110763
  • shrubitup
Posted July 14, 2013 - 04:29 PM
Thanks for the links. Yes, it does happen often as you describe during slow lug and chug woods crawls when it stalls and the piston lands on the compression stroke. I was rolling it forward in gear and should have went backwards as you suggest. Thank you! :banana:
:thumbsup:
Not running a Rekluse...... yet...
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  38 replies
  • On January 15, 2017
  • 10 replies
