Hone
5 replies to this topic
  • The_Dave
Posted December 16, 2003 - 03:48 PM
Fellers,
I have my engine (650R) apart to change out broken transmission parts and I am seeing that I am getting a little oil past the rings. Time to replace them. My question is can you run a ball-hone in the cylinder to break the glaze or will I damage it that way?
Thanks in advance!
Dave
  • irondude
Posted December 16, 2003 - 05:25 PM
its a no-hone chrome zone as far as i know...
Just had mine done by Barnumspro.com: As always they did a GREAT job, and worked late into the night just before the Baja 1000 to get my engine back to me for the pre-running.
Thanks Rob!
-new piston, rings, valves, rod, crank...went with the Kibblewhite valves/springs, Carrilo rod, OEM piston. Cant believe how much better it runs!
Unexpectedly found a 1/2 broken timing chain in the process and some VERY worn tensioner plastic plus the valves where tuliped (despite periodic tightening)...something to look for/just FYI. :)
  • The_Dave
Posted December 17, 2003 - 09:15 AM
Nowthen, if it is a "no hone crome zone" how do you go about getting new rings to seat?
Dave
  • BWB63
Posted December 17, 2003 - 09:37 AM
The cylinder is welded with a nickel and crome and rehoned. Or you can have it bored and a steal sleave put in for the 680 kit? That's what I am going to do a long with cam, bigger valves and what ever else Mr. Rob Barnums can work up for me. :)
  • The_Dave
Posted December 17, 2003 - 11:51 AM
Hmmmmm
Ok, I am not trying to be difficult her but I have no cylinder damage that I have to remove, I am not installing a larger piston, I am just replacing the rings and I want them to seat in. In the past I have run a ball hone through the cylinder to break the glaze and seat the rings. Nowthen, if you can't run anything through the cylinder to cross-hatch the cyclinder and break the glaze how in the hell do you ever get new rings to seat?
Has anyone out there replaced rings? What did you do?
Dave
  • madroberts07
Posted April 01, 2015 - 05:05 PM
I used a ball hone on my wr , it was nickel plated, and turned out fine. A ball hone won't take enough material off to go though the nickel plating.
