Side to side throttle play
5 replies to this topic
  • Strattos
Posted July 09, 2013 - 01:50 AM
How much side to side throttle play is normal and how do you adjust it out?
I've tried loosening the two phillips head screws that hold the throttle assembly to the bars, holding the throttle up against the bars and tightening the screws but it doesn't appear to have done much.
  • 123devinzz1
Posted July 09, 2013 - 02:33 AM
stock throttle tubes are plastic and wear out over time causing play
  • piwtorak
Posted July 09, 2013 - 05:07 AM
123devinzz1, what throttle tubes do you use or recommend ?
thanks !
  • 123devinzz1
Posted July 09, 2013 - 01:04 PM
thanks !
Never bothered me enough to replace stock one. You can get aluminum ones such as the tusk ones where it rides on a bearing and is nice and smooth.
  • Krannie McKranface
Posted July 09, 2013 - 04:42 PM
Ignore it
  • MANIAC998
Posted July 11, 2013 - 02:02 PM
If your talking about the actual throttle tube being loose, then ignore it like Krannie said.
But if your talking about freeplay in the throttle cables between throttle off & throttle on, then you can adjust the slack down near the carb.
