Yzf & yz rims compatible?
  • 1 year later...
Hello I have a 2005 YZ250 and a set of 2012 YZ450f rims. Can I get new bearings to make the rear rim work or is it a lose?
Look on here for 2009 yzf swingarm swap and it has a lot of info about the wheels. Long story short, there is no bearing with od and id that works for that hub and 22mm axle.
Correct, no bearing that has the correct ID or OD available for converting a 25mm hub to 22mm using just bearings. You're going to have to sleeve the unit down...
There are no bearing available...
As I said before use a spacer sleeve like the aftermarket companies do. It is a spacer to space inside your bearings with sleeves that go inside the bearing inner races to make them 22mm. Tusk impact, Talon and I'm sure others do this. I'm sure you could buy what you need from any of the companies buy purchasing one for their wheels.
