1999 WR 400 Rear Light Wiring Question
2 replies to this topic
  • Phat Twin
Posted July 07, 2013 - 04:57 PM
I am wiring up an Acerbis X-LED light on my WR400. I have it working, but only when the bikes RPM's are elevated beyond idle. I am curious if I might possibly have it wired incorrectly and was hoping for some input.
Here is the low down.
- Rear Hydraulic Brake switch
- Wires coming from the bike harness are Red, Blue and Black
- wires coming from the X-LED are Blue, Yellow and Green
I currently have it wired as:
- Red from bike, wired to One Lead of brake switch
- Blue from X-LED wired to other lead of brake switch
- Green from X-LED wired to Blue lead from bike Harness
- Yellow from X-LED wired to Black lead from bike Harness
When I increase the idle, the LED lights up, and the same goes for actuation of the brake pedal, illuminating as it should. It is just not very bright.
I am curious if I have something wired wrong or if my stator or wiring is need of help.
Thanks in advance!
  • Do I Care?
Posted July 07, 2013 - 10:25 PM
Your wiring must be different to AU but if it all works it is good.
The lights ''dimming'' is not a problem as the AC Magneto is designed to reach maximum lighting voltage around 3000rpm and dim when at idle.
  • Phat Twin
Posted July 10, 2013 - 04:47 AM
Thanks for your help, I wanted to make sure I didn't fry anything. Cheers!
