120 Width tire - hitting coolant reservoir.
8 replies to this topic
  • RMK800
Posted July 07, 2013 - 02:01 PM
I put on a 120 width tire on my 2007 WR450. I really like the bigger tire. About this same time I had a little wreck.
Those of you that have added a 120, do you hit your coolant reservoir or side panel?
I'm asking this because it could be that my sub frame is tweaked and that is causing my issue.
  • 123devinzz1
Posted July 07, 2013 - 02:27 PM
got my massive motoz 120 on and clearance is good.
  • RMK800
Posted July 07, 2013 - 03:11 PM
Mine only hits when hitting some larger bumps which isn't every time but annoying. I'm assuming you are fine when you are going through the bumps?
  • 123devinzz1
Posted July 07, 2013 - 03:56 PM
yess. no issues throughout its travel. Try adding a couple washers behind everything and see if it helps. You dont want that tire rubbing a hole in the bottle. You could end up sucking mud and dirt into the system.
  • Krannie McKranface
Posted July 07, 2013 - 04:12 PM
There is no reason for a 120 tire to hit the coolant bottle, unless it is a 'extreme' tire like the tractionator.
The 120 dimension does not account for side knobby width, so the fact that it is a 120 is irrelevant.
Check your wheel alignment.
  • 123devinzz1
Posted July 07, 2013 - 04:25 PM
The tire im using is the tractionator enduro it and its bigger (width wise) than all the other 120's ive used: kendas, michelins, bridgestones. That being said.. What tire are you using rmk? are the wheel spacers properly seated?
  • RMK800
Posted July 07, 2013 - 08:06 PM
I'm running the Maxxis Desert IT. Looking at my subframe with closer inspection, I believe that it's bent on that side causing my issue. I wrecked a few months before getting this tire and really never realized that side of the subframe. I have checked my wheel alignment and it doesn't seem off.
  • stevethe
Posted July 08, 2013 - 05:54 AM
We run a IRC 140's and nothing touches. Bend your sub frame back straight.
  • GCannon
Posted July 08, 2013 - 09:39 PM
Sounds like a bent Subframe to me?
