Squeaking rear suspension on my 426
5 replies to this topic
  • MiniMadMan50
Posted December 15, 2003 - 09:11 PM
Why is it doing this? Time for a lube job? It does it when I compress the rear suspension (sit on the bike).
Posted December 15, 2003 - 09:48 PM
Many times it comes from the top shock bearing. Try cleaning/lubing that first.
  • WR450
Posted December 16, 2003 - 02:27 AM
You will also find the the small knuckle that bolts onto the swingarm at the bottom.
These are the first bearings to go dry especialy if you clean with a high pressure cleaner.
Strip your swingarm and regrease it is a worthwhile exercise and should be done every six months to a year. :)
  • MiniMadMan50
Posted December 16, 2003 - 09:46 PM
Is that hard to do? I've had the bike since about.. June, and ride it almost strictly in the desert (very fine sand).
  • wrooster
Posted December 17, 2003 - 07:58 AM
> Is that hard to do?
no, it is not hard. however, it does take some time.
i did a complete writeup on the process, you can find it here:
also see this thread over in the YZ4xx forum:
jim aka the wrooster
'01 wr250f
  • Strick
Posted December 17, 2003 - 03:04 PM
I need to visit FAQ more often. That is an awesome step-by step.
