Excel rim ding removal tips...
6 replies to this topic
  • bajarunner
Posted December 15, 2003 - 04:39 PM
Is there a home remedy for removing a ding on a rim... I have a few little rim dings and I'm going to be selling it would like to clean it up...
any tips will help... with out destroying the thing.
Thanks
  • xr650Lroostnya
Posted December 15, 2003 - 05:38 PM
just take the hammer to it and beat the shiot out of those dents!!!! :) :D
  • bajarunner
Posted December 15, 2003 - 06:07 PM
YA.. thats my issue. Its got black Excel rims and I'm going after any bit of re-sale I can... Begging for re- sale!!!
So...I gave it one good hammer hit, to check the "paint may chip" theory and as I expeced it chipped off.
What would someone say about heat? maybe discoloring of the rim... (from a "shiny black rim with a dent" to a "very dull, burned spot, dented rim...?)
Tire on/tire off ?
on bike/off bike?
anything or ideas?
flatspot'
OUT
  • BrandonW
Posted December 16, 2003 - 08:02 AM
If you are talking about those big warps that happen to the rim when you hit a basketball sized rock at speed, here is a good one:
With the tire off, put the rim in a vice. Cut down some bolts so that they just fit inside the rim, and space them just *outside* your bent spot. Then, tighten the vice.
This will draw in your bent-out sidewall.
Use a cloth between your rim and the vice, and they will still look purty.
  • JackAttack
Posted December 16, 2003 - 09:11 AM
I tried the vise theory, and after a few twists of the vise handle, I cracked the rim. :D
I went back to beating them out with a hammer.
BTW, can a cracked rim be welded? :)
  • irondude
Posted December 16, 2003 - 11:47 AM
There are so many bent rims out there. Why doesnt someone make a large stamp of the rim with a hydraulic press-to re-form them? Almost everyone has a dent or two.
I have had success pounding the small ones out a bit, but not much.
I had to deal with a severaly tacoed rim in Baja recently. The inner tube was showing-although it never went flat.
Anyway-i went to a Mexican tire changer--those Baja Mexicans can fix anything with a hammer, screwdriver, and some wire....so we took the tire off. Put LOTS of heat all around the bent spot-the 'heat' was an old paint can full of clay with about a pint of siphoned gas in it. It burned hot for 1/2 hour! SO after 10-15 minutes of putting the bent part of the rim over the fire we put the bottom part of the rim (un bent part) in a large vice to hold it. WIth me holding the other side of the wheel for support the mexican took monkey wrench/pipe wrench and just worked the bent spot - bending it back!
He moved it about an inch!!!
I told him to stop as i was sure it was going to crack-he said we could keep going--but really it was good enough for me. Cooled it in a bucket, put the tire back on--and the bead was fully contacting aluminum. It was a bit discolored-but nothing that couldnt be worked out with some Mothers Aluminum Polish. The rim made it the rest of the trip--maybe 250-300 miles. No flats....
I think the heat was hot enough to soften the aluminum, but not hot enough to burn some of the trace elements out of the alloy--meaning it was probably only a bit weaker than when we started, but not by as much as a gas torch might do.
SO anyway-- maybe some sort of combo heat (carefully applied) and then a vice (with wood or thick cloth at contact points) with monkey wrench or vice grips (again with cloth at contact points) is the way to go.
just an idea-
-M
  • Moredesert
Posted December 16, 2003 - 05:17 PM
I have gold rims and I use the hammer trick all the time. When I change tires I look for dents and hammer them back :D. I take the rim and lay it flat on the concert step in my garage and beat it with a lead hammer :D :). I also use a rag under the rim so it doesn't get scratched on the good side. :D
  • 22 replies
Honda XR650L 2016
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  60 replies
