Drop height
1 reply to this topic
  • allterra
Posted June 22, 2013 - 12:45 AM
Just for sake of mind what height should the 07 wr be able to handle on a ledge drop ----____ to flat ground prior to bottoming out. Let's assume it is set up for general trail. I do turn up the compression damper a lot when I know we are riding the ledges.
  • Krannie McKranface
Posted June 22, 2013 - 04:19 AM
If everything were brand new, 185lb rider, I'd say 6'.
But the question doesn't take into account so many other variables, it's kind of pointless?
The fact that the stock oil is so poor, it would not take long before it no longer works at all....like 20 hours.
If the shock is set up correctly, you should not have to re-adjust it for different terrain types.
The High Speed compression adjuster is more important here than the low-speed compression adjuster.
