Ok like the tile says no spark , so this what I've done 2006 SM
replaced stator with a Ricky stator . was very carful to run wires correctly and used lock tight
did the free power mod then un did power power mod ran wires direct with out connection
double triple checked my wiring I have clutch , side stand and turn signal relay gone ( bike ran last year with current wiring configuration)
so today I tried to test my RR using a small LED bulb and known good 12 v battery from FAQ section
test results.. from positive to black wire no light .. from neg. to red wire no light... and from positive to red no light from -neg. to black no light
not shear what if anything this tells me WIRES FROM RR WAS TESTED
and jumped from my jeep to bike (motor off on jeep ) to make bike battery just as too low still no spark
have eddies cap on coil mod also hooked up stock coil still no spark
new spark plug
help
still battling no spark problem
Started by
suzuki sm nut 123
, Yesterday, 05:41 PM
1 reply to this topic
Posted Today, 03:42 AM
I was having problems with my street bike, and after much fooling around, it turned out to be corrosion at a couple of grounds.
2 user(s) are reading this topic
2 members, 0 guests, 0 anonymous users
backyard hack, underbike
Follow us:
