Floating piston showa 47 mm
2 replies to this topic
  • Hydrodydrododecahedron
Posted Today, 12:44 PM
Hey people I noticed a rattling noise from one of my forks today. Took them apart to find the floating piston and ics spring were rattling round.
Just how much play should be in the floating piston?
Also one fork the inner chamber system still worked and extended the rod fully out but the rattly one actually sucked the rebound rod in vacuum style!!
Oil was gone. Bottom seals aren't leaking so I'm assuming oil went past the floating piston?
Here's a pic of the play in it.
Any thoughts please and what do I need to fix this.
  • wblake
Posted Today, 01:31 PM
its held by oil pressure from the cartridge, its because it leaked that why it was rattling, you have ics oil seal leaking or o ring, replace them and bleed them the rod should extend fully...
Posted Today, 02:31 PM
Yep just ordered seals.
Every time I ride this &%$#@!ing thing something breaks. ๐Ÿ‘Ž๐Ÿ‘Ž๐Ÿ‘Ž๐Ÿ‘Ž๐Ÿ‘Ž๐Ÿ‘Ž๐Ÿ‘น
