WR450F Max hours on engine?
49 replies to this topic
  • supernick
Posted June 14, 2013 - 07:30 PM
Im about to buy a 2004 Wr450f and going to make it street legal. How many hours can be put on the enigine before it begins to show signs that it needs a rebuild? 50? 70? 90? let me know.
  • Krimble
Posted June 14, 2013 - 08:11 PM
I have seen people do 100-150 easy. Good maintenance like frequent valve checks, oil changes and cleaning air filter can really increase the hours capable.
  • Monk
Posted June 14, 2013 - 08:47 PM
  • GuyGraham
Posted June 15, 2013 - 01:03 AM
I have 5500 miles on mine (2008) which is 90% dirt and I average 20mph on the dirt so that makes 275hrs
I haven't been into the engine yet
Oil changes every 10 -15hrs, with filters every other, and valve checks every year
I don't bang it off the rev limiter
The bikes history is more important
What oil has been used?
Hows it been ridden?
Hows it been maintained?
a bike with 20hrs on it that's been run low on oil is gonna be trouble!
WR engines have a reputation for being super reliable with 10000+ miles easily achievable before engine work is needed, but if they've been mis-treated.......
Edited by GuyGraham, June 15, 2013 - 01:04 AM.
  • Parx_400
Posted June 15, 2013 - 09:14 AM
I put 5000 miles on a 05 that had already been semi abused as a motard. no idea how many miles total it had already. bike ran like a champ.
  • Krannie McKranface
Posted June 15, 2013 - 03:14 PM
300 hours, easily.
I went 650 hours on my '03 before removing the head for the first time....
Posted June 16, 2013 - 12:02 PM
Depends entirely on usage. Raced constantly, 50-75 hours tops (they can go longer, much longer even, but risks arise). Easy trail riding, 400, 500, even 600 hours can be possible.
  • Stealth13
Posted June 17, 2013 - 07:15 AM
My last one had 7200 km and who knows how many hours. Still ran ok but was smoking some blue. It was drowned a couple times as well :(
  • Strattos
Posted June 22, 2013 - 02:47 PM
LIke others have said all depends on how it's been looked after and how its been ridden.
If you can get an honest answer from the person you're buying off in terms of how its been treated and maintained, then you're pretty safe with some of the fugures being quoted above.
I've got more than 160hrs and 8500kms on my '08 and still doesn't use a skerrick of oil or blow smoke. Starts perfectly.
Having said that, I'm only a clubman enduro racer. If you look at how hard some of the Pro class guys ride, you'd have to expect it would take a much higher toll on the bike. Many variables to consider.
  • MaxPower
Posted June 22, 2013 - 09:25 PM
How much skerrick?
  • Adamridesorange
Posted March 11, 2014 - 10:17 AM
I know this is an old post, but I'm trying to figure out how many hours to go on a wr450f and everyone is telling me 200 hours is the max I should go for trail riding. One guy said he went 300 and it was a little bit too long, and the piston was touching the bore. How are you guys getting 650...!? I mean these are still high revving racing motors...
  • woods-rider
Posted March 11, 2014 - 10:35 AM
I put about 1,000 hrs on my 2006 before I sold it. This is trail riding at 40 expert pace. Never any engine problems. Just did regular oil changes and a few valve checks. These things are solid.
Edited by woods-rider, March 11, 2014 - 10:37 AM.
  • 3MTA3
Posted March 11, 2014 - 12:31 PM
You will become a believer :cheers:
  • Adamridesorange
Posted March 11, 2014 - 01:31 PM
1000 hrs without ONE rebuild?!? That just doesn't seem possible. I don't even think an XR can do that!
  • Adamridesorange
Posted March 11, 2014 - 01:44 PM
There's no way you can go that long without even a piston change..I'm having people tell me 300 hrs is too far...
  • KennyMc
Posted March 11, 2014 - 05:06 PM
Give me a year and I will have the 300 hours and I won't do a thing to the top-end.  I will have to ride a bit more, but I will be willing to put in the extra effort for the cause :thumbsup:
  • Adamridesorange
Posted March 11, 2014 - 05:10 PM
Are you guys bikes all stock that are getting these insane top end hours? Stock bikes, or stock anything for that matter seem to last longer then modified bikes
And by stock, I mean like not "uncorked" like a lot of people do
  • jrmxrc
Posted March 11, 2014 - 06:55 PM
I just wanted to add my own story here. I have a 2008 wr450f with approx. 25000 miles on it. It has been desert raced, been to Baja  many times, is trail ridden about 2 or 3 times a week on very rough and nasty Northern Nevada trails. I'm far from slow as I'm a former local mx pro and a expert rated desert racer . 6000 miles ago it got its first new piston and it just got new valves. Its still on the original crankshaft, but I did have to replace the trans. output shaft because it stripped out. I have always used Rotella T oil and change it often. These bikes are bulletproof if you just take decent care of them. The bike is  uncorked, jetted, piped and modded suspension.
  • Adamridesorange
Posted March 12, 2014 - 02:45 AM
Do you know how many hrs was on your first piston?
  • Adamridesorange
Posted March 12, 2014 - 02:51 AM
Are all you guys others bikes modded or stock? It just seems to me if the WR is putting out close to 50hp compared to the stock 37 or what ever it is, it's going to be about as reliable as the yz450f as the motors are almost the same, and the yzf usually lasts about 100-150 hours trail ridden..
