Anyone have a petcock problem with Clarke tank?
7 replies to this topic
  • MotoGreg
Posted December 12, 2003 - 09:52 PM
I had a Clarke 3.3 gallon YZF tank on my bike for a while, the one that a lot of people here use on their WR's with the YZF style seat. I sold it to a guy (thanks to TT) yesterday and when he put it on his bike today he said there is a gas leak around the petcock. He took it back off and flipped the o-ring over and it still leaked, but not as bad. I never had any problem when the tank was on my bike. His bike is an '02 yzf426 so it seems odd that the 0-ring seal would be bad already, but I guess it is possible. Has anyone else had a problem with that?
  • tp3dxf
Posted December 12, 2003 - 10:08 PM
I have the Clarke tank on my WR426. Today while working on my bike I happened to notice that the gasket was all cracked. It's not leaking but I should probably replace it soon. I put the tank on about a year ago.
  • Moto-Mike
Posted December 13, 2003 - 07:08 AM
I had the same problem when I bought a used IMS tank. After several failed attempts to stop the leak I called IMS. They sent me, free of charge a thick gasket to go between the petcock and the tank. Problem solved. Kudos to IMS. Even if they charged a little it would have been well worth it. :)
  • RCannon
Posted December 13, 2003 - 11:42 AM
I had the problem on an IMS tank. I ended up fixing it by using some silicon lube/ sealer (quite thick) on the o ring. With the stock factory gasket, the surface has to be perfect!
I used a knife sharpening stone to make the area smooth first.
Overall, the IMS tank sucks.
  • Ridin'_MD
Posted December 13, 2003 - 01:29 PM
I had the same problem with my NEW tamk from clarke....I actually removed the gasket and put the petcock directly on the plastic..NO LEAK!!!
Works great for me and I cant see what the drawbacks would be. Have him try that.
I have changed tanks many times always using the gasket for stock and no gasket with the Clarke.
Good luck, Bud :)
  • Pazzo_P
Posted December 13, 2003 - 02:19 PM
I had the same problem, fixed it using this on the petcock O-ring ”Permatex Form-a-gasket 2B”. It's Gas/Kerosene specific. Get it at any Auto parts store. Over 14 X/C races and no leakage. :)
  • dirtbikindad426
Posted December 13, 2003 - 04:10 PM
I went and got a new petcock gasket and put it on works like a charm. Thanks guys.
  • PowerFiend
Posted December 18, 2003 - 07:54 AM
Just put an IMS tank on my 02 WRF and had to replace the stock petcock o-ring style gasket due to leakage. It was already hardening.
